ka3jjz
Wiki Admin Emeritus
There is a message in this entry saying that only the TRX1, 2, BC436 and 536HP scanners with updates will copy DMR in the Misc System Information area
Bay City Governmental Services Trunking System, Bay City, Michigan - Scanner Frequencies
This list is not complete. The Whistler WS1080, 1088, 1095 and 1098 scanners also got updates for copying DMR, per this...
https://whistlergroup.com/blogs/news/whistler-launches-dmr-capable-scanners
In addition, you can use DSD or DSD+, for example with either a tapped scanner or a SDR (The AOR DV-1 doesn't do DMR trunking yet, so it's not applicable here)
In order to have a standardized way to capture all of this, templates were developed for use in the wiki. Specifically, this one covers DMR / Mototrbo
Template:Tracker DMR - The RadioReference Wiki
Perhaps a standardized message put into the Misc System Information area pointing to the DMR and MOTOTRBO entries in the Glossary could be coded to cover this. That way if a new scanner comes out with DMR/Moto, then it's a snap to enter it into these 2 articles. No need to add it to each and every db entry
Mike
Mike
