Radio Management 2 vs. CPS on IPSC
KA5YTH
Bolivar, MO
We just deployed Radio Management 2 to our fleet of about 80 radios on an IPSC system. This is an upgrade from traditional CPS and USB cables. I was really excited thinking it would cut down on having to modify every single codeplug. But, after playing with it, it still looks like I have to.
In fact, I think it is going to take longer because I can't figure out how to copy and paste between configurations like you can between codeplugs in CPS. Right now, I'm a little frustrated.
Am I missing something? The only advantage for Radio Management for IPSC that I can see is you can program over the air (only for version 2 radios - which is only about 60% of my fleet).
Anyone using RM2 on something other than Capacity Plus that can give me some tips and tricks?
Sent from my SM-G900V using Tapatalk
Firebuff880
Boynton Beach, FL
Sounds like you are in template mode, which is supposed to be simular to RM 1. Although there are many changes such as the code plug template is now stored as an SQL stream file inside the database.
Later you may want to experiment with the new "Configuration mode". But be very careful as once you go to this you can no longer use standalone CPS to change anything in your system.
Watch for next release sometime in January.
KA5YTH
Bolivar, MO
I'm in configuration mode, but the only "sets" available so I don't have to copy and paste are voice announcements and capacity plus. If sets we available for everything, it would be amazing.
Firebuff880
Boynton Beach, FL
--- Probably will take a number of releases to get there. I think focus right now is Capacity Max.
Firebuff880
Boynton Beach, FL
Sorry, I'm totally not up to date on this at all. Is this a new radio programming software system, maybe even one that handles multiple types of radios in one package?
Yes an No. M is moving towards using radio manager II as an eventual repack mentioned for CPS.
Although CPS may still be around for ones and twos. Once you do a system set with RM II you can not use CPS again.
KA5YTH
Bolivar, MO
Supposed to be able to use different "configurations" referencing the same "sets" across different model numbers. Sounds like an awesome idea, but doesn't quite live up to my wishes... Yet.
dkaskie
Jeffersonville, IN
I have been told that once a radio is programmed with radio management you can no longer program it directly with a cable any more. Is this true??
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
False. TT
(Well define "directly". You can no longer use CPS. You can still use every method available tot he radio like cable, bluetooth, wifi, and OTA. RM is for larger fleets where you want to see every detail with every radio in a large database. It also enables you to offload the physical touching of radios to less technical people. We use it for Cap Max and to do programming on fleets larger than 100 radios. Where one programmer guy can control 1-16 (or more, I forget) remote programmer devices.) TT
Thunderknight
Bletchley Park
I don’t know about MotoTRBO but with an APX and RM, you can use a cable and CPS, but then you need to read the radio back into RM afterwards to be able to write a job to it. If not, the RM job will fail with an error that the radio was programmed outside of RM.
But the APX radio is fully capable of being touched with CPS and a cable...it’s just not the best way as it takes it out of sync with the RM database.
N1GTL
CT
I have not seen it mentioned but in order to assign a template to a specific radio, the target radio MUST have the same firmware version as your template. This is the problem when adding radios to your fleet over time. Motorola releases new firmware and the old templates will not work. You have to create a new template with the new firmware version.
TampaTyron
Phoenix, AZ
We were told in the Motorola Roadshow that even stand-alone CPS will be moving to the RM style of display. It was strongly recommended to learn it ASAP so that we were not left out in the cold. TT
