MCS2000 Change Head Type
cobraultra
Pittsburgh, PA
So I got a MCS2000 Type II. I have the Dual head option with Type II Heads. When I read the radio it comes up with Type III. How do I changes this back to the Type II for the heads I have? Thanks!!!
cobraultra
Pittsburgh, PA
Great page Skypilot. Thanks
So Looks like i have a Type 3 according to the Model number.
I have heard of people changing there Type 2 over to a Type 3.
So i wonder if there is a way to change it back? or in this case change it initially.
Skypilot007
Medford, NJ
Control heads have become relatively cheap on ebay for these radios. I would just get the correct control head for it to make life easy for yourself. Changing the model number of the radio could be done with the proper software tools but why bother downgrading your radio to a model II.
cobraultra
Pittsburgh, PA
Yeah i have seen then online but i have this setup for a dual head system and really didnt want to buy two new heads. I have the FDB tool if that will do it. I also have access to radios that are type 2 if i need to read it from.
Skypilot007
Medford, NJ
FDB may work. It's purpose was for modifying radio features, not sure if you can change the model with it. You could always experiment and see what happens. Be sure to save your original s-records before starting! Read a model II and a model III and look for the obscure differences. It may lie in one of those unmarked blocks. That's where I found the block to increase the number of channels in these radios.
yaknamedjak
localhost
MTSX Lab, from what I have read you write an s-record of the desired model with no pack/unpack. I am getting ready to attempt it on my VHF Model 2 110w, trying to turn it in to a Model 3..
Model 3 Heads w/ mic $25 on eBay, I would get that.
ke5eua
Zachary, LA
I have two MCS 2000 radios,
M01KHN9PW5AN 136-174 25W Type 3
M01RHM9PW5BN 403-470 25W Type 2
What I want to do is get a type 3 head and swap on to the uhf radio. Since I have already read and programmed these radios with CPS would the RSS MTSX lab even work with them?
Were you able to convert your type 2 into a type 3?
