Just picked up this old scanner to play with, it is possible to monitor OPP with this unit?
So far have programmed in local ham repeaters with success!
You will only be able to listen to analog Beat Repeaters or mobile portable repeaters. That's it. Otherwise you will need a digital scanner. All the frequencies you need are all readily available in the database. Check it out.
