Ef johnson 51sl programming
hou30guy
humble tx
I had this radio programmed at a communications store that does all the local tow trks, it is monitoring only so im guessing a key had to be used to program. My question is if i buy the software and cable am i able to add more channels and or frequencies with out a key at this point or would i need a key.
marksmith
Anne Arundel County, MD
If you are guessing that a key was required to do the original programming, I am guessing it would be needed to add more channels at this point. It is usually the key that enables programming mode at all, and not just required to enter a frequency, as programming can also re-enable transmit mode.
Sent from my LG-V410 using Tapatalk
INDY72
Indianapolis, IN
Not an scanner! Please go to the other forums set up for discussing professional commercial radios.
KevinC
Other
Super Moderator
Home
The proper response would have been to report the post (which someone else did) and ask to have it moved. Not post the same question in a different forum, which is cross-posting.
hou30guy
humble tx
I dont recall posting this anywhere else sorry wrong person, and i wasnt sure if a key was needed or not to program, im able to get my hands on software and cable just wanted to know before i waste my money, didnt know also if i needed a key to rearrange my button functions
hou30guy
humble tx
Fourms have rude ways of answering a person question, if im posting in the wrong area i sure would like to kbow instead of getting told on like we are little kids gosh
kayn1n32008
ØÆSØ
Sector 001
Unless the mods happen across the post, the only way to get it moved in a timely fashion is to report the post. You were not 'tattled' on. Posting in the proper forum will get the best results to questions. Not everyone reads every forum.
KevinC
Other
Super Moderator
Home
Maybe you didn't notice, but I quoted a different member, advising HIM to not advise other members to cross-post (which is what he did). You only posted your question once.
hou30guy
humble tx
Oh ok sorry thought it was directed to me, probably just go g5 unication route depending on how i like my ef johnson
KevinC
Other
Super Moderator
Home
I had a G5 for a short while and was impressed with the audio quality on the system you are trying to monitor.
hou30guy
humble tx
Yesterday i hit up unication on fb and they said its a option for phase 2 on there, they would pm me pricing, so u think its something in the software that can enable it?
