XTS1500 Firmware Update
ryolsen8
BEE07
Hi Folks,
I would like to update the firmware on my XTS1500. I am not entirely sure what I need as far as iButtons, files, etc. I do program it, but when it comes to actually updating the radio to the latest and greatest, I don't know much. My CPS version is R20.01.00. Currently, I am not able to display time on my screen, nor am I able to have the Channel Announcement enabled.
Thank you!
N4DES
Retired 0598 Czar ÆS Ø
South FL
You would need a flash dongle and the firmware file and both are available from Motorola for around $75.00 to do a FW bump. Nothing special is needed to preform the update and is accomplished in CPS.
If I recall the XTS1500 only came in a Model 1.5 that doesn't have any soft keys so you will not have a way to set the clock to the right time so the codeplug should not show it.
The question I have is do you have an A model or a B model? And what FW is currently in the radio because an A model is only capable being brought up to version 9 FW.
N1GTL
CT
Back in July 2016 I was told my Motorola that you can only order FW upgrades for those radios until 12/31/2016. It may be too late.
N4DES
South FL
I'm pretty sure that was for feature set enhancements. The FW is still available on MOL so all he has to really order is a flash dongle.
He hasn't responded with the model type or his current FW version, so until he does that there is no way to know if a FW update is even worth it.
ryolsen8
BEE07
I do believe I have a "B" model. The model number is H66KDD9PW5BN. The Portable also says Bravo122, when I enter it into Service Mode.
N1GTL
CT
I'm not going to dispute this but I work at an /\/\ shop and called with the question "how long can I get the USB upgrade for firmware dongle for Astro series radios" and I was told 12/31/2016.
If it is still available, you should be able to get it from the Mighty /\/\. If not, you need to get it from someone who might have some dongle upgrades "sitting around".
N4DES
South FL
Yes you do have a "B" model that can be updated to version 20 FW, the question is when you put into service mode what FW does it show?
N4DES
South FL
Yup...there were a lot left over from Rebanding, but the question is to find someone around him that still has them available.
ryolsen8
BEE07
Host Version: 11.00.01
DSP Version: 11.00.00
8 MEG
Tuning Version: R01.09.11
All I really want to add to it is the channel announcement... :)
N4DES
South FL
FW could use a bump, the P25 audio quality made a drastic improvement around version 14 of the FW/DSP. As to adding features, that looks to be off the table.
