Motorola HMN 3000B-9637 Desk mic, want to convert it to a PC mic
Hudson, MA.
Hello all, I acquired a Motorola HMN3000B-9637 desk mic from my local FD that has had it's Jx connector cut off, showing just wires, how would I convert the x amount of wires to allow the mic to work with a Windows PC? I thought it'd be a fun project but I need a little help on a wiring diagram and how that would interface with a 3.5mm mic jack on the back of a Windows PC.
Any help would be appreciated.
If this is wrong forum please move it to the right one :)
Easiest way would be to gut it and take an existing PC mic and install it inside the housing.
Many of the Motorola mics require a bias voltage to work. You won't get that off your PC mic connection.
Hudson, MA.
aww... I wanted to use the moto mic because moto mics are awesome.. and they have good audio quality.. and I may just gut it, or keep it whole..
Yeah, I understand.
It could certainly be done, but it'd take some work. I'd have to dig into it, but I think it's 8vdc bias voltage on the Motorola mics. You'd have to feed a clean 8v supply into the mic.
Not impossible, but not easy, either.
cmdrwill
So Cali
No NOT 8 volts directly. 6 to 9 volts thru a 560 ohm resistor.
And YES PC does supply a 'bias' voltage thru a resistor to the Mic hi.
