After monitoring the Delta system I suggest the following changes to the database.
I submit them for your approval/comments.
Remove "Delta" from the display name.
TG Display Name Description
4128 De-Icing Pad Ops De-Icing Pad Operations
4144 B Gates B Gates Coordination
4176 C&D Gates Alt Alternate channel for C&D gates
4272 De-Icing Ch-3 Alternate channel for De-icing Pads
4304 De-Icing maint De-icing Equipment Maint
4512 Avionics Maint Avionics Maintenance
4800 De-Icing Unk De-icing use
37136 Gnd Cntl Tower Ground Control Tower Tie-in
