Greendale & Hales Corners Merging to One Dispatch
mkescan
Milwaukee
Greendale PD & Hales Corners PD are Patched to 38355 if your Uniden scanner status bit setting is set to Yes. If your Status bit is set to Ignore. you will hear both Depts on the HCPD & GDPD Talkgroups
prowisscan
Milwaukee, WI
With this switch and the merge onto the Milw. Co. TRS TG 38352 for both Greendale and Hales Corners PD, I am wondering if this will also impact the TG for both PD patches on the WISCOM system. On the Greenfield 800 site, 41721 was the Greendale PD patch and 41741 was the Hales Corners PD patch, I would assume the latter is quiet now? Work has been keeping me away from the scanner lately.
kylem1229
The Greendale FD and HCFD also seem to be patched together.
