SDR Trunk .0.2.0 Issue
BM82557
Berkeley Co WV
I am using version 0.2.0 on site 001-017 of this system - First Responders Interoperable Radio System Team (FIRST) Trunking System, Various, Maryland - Scanner Frequencies
It looks like SDRTrunk has a problem. it reports 774 MHz freqs as 786 MHz.
First attachment is SDRTrunk 0.2.0 -
Second attachment is from Unitrunker -
I don't know if SDRTrunk version 0.3.0 has the same issue as the waterfall freezes up after 10-15 seconds and the only option is to close it out. 0.2.0 runs fine on the same machine, Win 7 64 bit, Java 8.
DSheirer
Fulton, NY
Could you please post or send me the Activity Summary from that control channel? Right-click on the channel in the lower-left corner after it's been running for a short while and choose Activity Summary. The text should show the frequency band info.
Denny
BM82557
Berkeley Co WV
Thanks for your quick response. Has anyone else reported the other problem? -
"I don't know if SDRTrunk version 0.3.0 has the same issue as the waterfall freezes up after 10-15 seconds and the only option is to close it out. 0.2.0 runs fine on the same machine, Win 7 64 bit, Java 8."
DSheirer
Fulton, NY
Is this with the beta 2 release, or an earlier alpha version?
BM82557
Berkeley Co WV
v 0.3.0 beta 2
Looks like the machine I was running it on (Pentium Dual Core @ 2.10 Ghz 4 Gig Ram) caused the problem. I installed it on another machine (Intel Quad Core I3 @ 2.53 Ghz 4 Gig Ram) and v 0.3.0 beta 2 is stable.
DSheirer
Fulton, NY
The freeze up problem was (hopefully) fixed in 0.3.0-beta4. The issue with correctly parsing P25 Phase II TDMA channel frequencies is now fixed and will be included in the next beta release (0.3.0-beta5).
Denny
