Extended Range Direct Mode
N1GTL
CT
I am reading about this new feature that allows a single frequency "repeater". The system planner mentions using two antennas with separation specifications based on frequency.
The last thing the system planner refers to is "A single antenna may be used in conjunction with an RF switch capable of handling the repeaters TX power. GPIO output pin T/R Switch is be used to drive the switch."
Does anyone know of a specific part/model number capable of an RF switch that can handle the rapid switching of MOTOTRBO?
jruta
Nj
Single frequency repeater? Sounds like a "catch and release" forwarding repeater. The type that receives then re-broadcasts the signal on the a single frequency. Cheap little things and to my knowledge Moto never produced such an item. Only confusing thing is this would only require one antenna- and no "switching" involved. Unless I'm way off here, that's the closest thing that "kinda" fits the description that I can think of.
N1GTL
CT
It uses the time slots for transmitting and receiving at the same time. If a subscriber is getting a better signal from another subscriber, it will "vote" that signal. If the signal is better from the repeater, it will use that signal. You can use 2 antennas with proper separation but it also mentions a TX/RX antenna switch. I found a Teledyne coax switch with 10ms switch times but I am not sure if I am looking at the right thing.
This feature was introduced in version 2.7.1 I have a few SLR5700 repeaters I can try this. I opened a case with /\/\ seeking an "officially recommended" T/R switch so if something blows up, it's not because I picked the wrong one.
I remember the "simplex repeaters" of the 1980's ham era where it recorded the TX then played it back. This is not the same thing. The voice delay is 90ms.
jruta
Nj
Ah interesting. Never knew that existed. Time for me to read up on MotoTurbo
N1GTL
CT
Have you looked at Wayne''s post...
Extended Range Direct Mode - DJ0WH
I did see that post which gives a very basic explanation of how it works. It did not address exactly what part number/antenna switch is needed. I did get a reply from /\/\ tech support today; I just did not have time to look up the make and model numbers of what they provided. I'll follow up in a future post if anyone is really interested.
N1GTL
CT
Here is the list I got for antenna relay options:
0310909E68 SCRTPG,M4X0.7X35,STARPAN STL ZINC( 2 req’d)
30009310002 CABLE, ANT RELAY DC
3084921Y21 RF CABLE,PA(N) TO ANTENNA RELAY(N)
40009272001 COAXIAL RELAY, 14V
ZS6HZ
Sønderborg, Denmark
I'm doing some investigating into setting up a two site ERDM system, so I'm looking at using a single antenna system at each site. The relay mentioned in N1GTL's post looks like an electromechanical relay that is used to allow a single antenna to be used if an SLR8000 repeater is in "Base Station" mode. It won't last very long if used in ERDM mode because it's life cycle of several million switching cycles will be reached fairly quickly if it is switching at 30ms bursts.
I've tried looking for PIN diode switches or other solid state devices, but I'm drawing a blank wherever I look.
Any ideas?
BTW, I have tested ERDM here in Denmark, and it seems to work very well indeed. You get repeater-like coverage on a simplex channel, and the portables select between repeater use and conventional simplex even within a call, so you can travel in and out of the coverage area without dropping calls.
ZS6HZ
Sønderborg, Denmark
Thank you for that information. I contacted RF Technology and they sent me some pricing information. They say they don't know what the switching time is for their switches, but I guess it should be fast enough.
I'll put in a formal request with my company to buy a sample and will get some testing done when I get a chance.
