FR6000 Analog/Digital Mixed Mode Operation
BlueDevil
WA
What is the best way to setup the Icom FR6000 UHF Repeater for Mixed Mode Operation. Or at least I think it is "Mixed" mode that I want. I would like the repeater to be setup this way:
Analog In = Analog Out
Digital In = Digital Out
BlueDevil
WA
The only solution I have come up with is far from perfect or great but it would be to set the repeater to scan both the Analog and Digital Channels.
stevelton
Enter the freq. Set the "Operation Mode" to repeat.
Set CH Type to Mixed- Ana or Mixed-Digi, depending how you want the repeater to transmit from its local mic.
Make sure in the Common folder -> Commond page at the bottom, Digital Function is set to Enable.
This should make it work. If not, you may need to upgrade firmware.
Steven
