Quick Call II question
FirstDue5
Georgia
So my department uses DTMF tones to tone out specific stations, and then 2-tone for volunteer paging (combined fire department) and I'm trying to figure out if the 2-tones that they use are quick call, how would I go about finding that out? I have a CP200 and I want to program it to alert for the 2-tones
N1GTL
CT
Lots of phone apps out there what can listen to the tones and tell you what they are.
FirstDue5
Georgia
Yeah I have an app that is supposed to detect MDC-1200 and QCII, but when my department tones go off, it picks up nothing, leaving me thinking that they are not QCII tones. Am I still gonna be able to program the cp200 to tones even if they aren't QCII?
jim202
New Orleans region
The best way to figure out if your looking at QC-2 or something else is to pay attention to the duration of the tones.
You can do a simple search on the internet to get information on the exact timing so we don't give you the wrong information. It should also provide the tables that have the different tones.
I know this is not a very good answer, but it would help if you supplied more details.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Someone in your department should know what the tones are. If you have someone who takes care of your pagers, he or she would most likely have that information.
This file will help you program your CP200 for Quik-Call II: https://drive.google.com/file/d/0B3k529wkRVv1WDZKRVdVZ084eDA/view?usp=sharing
FirstDue5
Georgia
I got the tones that I needed, thanks for the help. but now, I do not see an "AND" or "OR" in my personalities, there is no "PTT Sidetone" "PreTime" or "Long Tone Duration" options in my Quick-Call II ....Do I need to update something on the radio? I have CPS RO5.16
SteveC0625
Modified info for your CP200, ignore those settings except And/Or. See below.
Make sure you are in Expert View. Click the view button at the top of the window to change from Basic to Expert.
On the personality window, on the Rx side, set your Rx signalling to be Quik-Call II System 1. Then the Signalling Squelch box will let you change to AND or OR depending on how you want this set up.
FirstDue5
Georgia
So the tone I want to put in, is a volunteer 2-tone, with the A tone being 1102.0 Hz lasting 1.2 seconds according to Two Tone Finder. B tone is 457.0 Hz lasting 2.2 seconds, again according to Two Tone Finder. I do not believe that these are QCII, but can my radio still decode these?
SteveC0625
Yes, your radio should decode them.
I don't find those tones on any of my charts. Try RadioID on your smartphone and see if you get different readings. It won't give you the timing, but I find that it is more accurate for the tone frequencies.
One second/two seconds is pretty standard for most two-tone decoding these days so don't get too hung up on the exact timing.
