MD-380 Problems in Newberg
GrumpyGuard
NEWBERG
Over the weekend I picked up a TYT MD-380. I attempted to program the radio but my win 10 computer and the software would not talk to the radio. Today I attempted to update the firmware. Now the radio just lights up and beeps. Is there anyone in Newberg or the surrounding area available to help me get this radio updated and programmed?
Thanks,
Matt
KG6YLJ
bears3312
camas wa
Thanks,
Matt
KG6YLJ
I have one I live in camas wa what firmware are you tri to get
thanks bears3312
GrumpyGuard
NEWBERG
The original firmware was D013.020 with CP Vol 1.30. I attempted to upgrade to TYT-TFT-MD380-D3.32. I hate to think that I bricked this radio.
cinsu
WT44
What are you trying to program into it?
cinsu
WT44
I just got on recently myself with a Tera 4400. Not sure what the firmware update issue may be but sounds like it got stuck along the way somehow.
Did you get an ID from DMR-MARC already?
GrumpyGuard
NEWBERG
I am waiting for my ID. with the holiday weekend it might take a little longer. Something I noticed about the repeaters in Oregon and Washington is they don't have time slots or talk groups listed. When programming these into the radio do we just assume that it is time slot one?
cinsu
WT44
Search for the PNW DMR website. A TON of good info on there. The time slot is associated with the talk group and PNW DMR will list each talk group that is available. The North Oregon repeaters operate different than most so be sure to read thru that. When you get online there are a couple nets on Wednesday on PNW 2 and Oregon 1 and a national net on Tac 310 on Sunday
pro106import
Milford, Ct. perched high above Long Island Sound
You didn't brick the radio. I do not have the radio yet. Just bought one today. Probably have it by Sat. According to what I read, you put the wrong firmware in the radio. Instructions I have found I copied and pasted here:
"The MD-380 has two versions, new vocoder and old vocoder, so please check version first in the radio, check menu-utilities-radio info-versions and if you find the version is D002 and D003, it should the old vocoder and the latest firmware is MD380-D3.20, while if the version is D013, the firmware should be MD380-D13.20"
Get the correct one here:
Programming Software & Firmware
Hope this helps,
Bob
GrumpyGuard
NEWBERG
I was able to put the experimental version of the firmware on the radio and it now boots. Now if only the programming software would communicate with the radio.
Pro106inport thank you.
pro106import
Glad I could help. I also read that Windows 10 doesn't like the drivers too much. Maybe it was just that persons setup, or maybe there is something to it. I always keep an old laptop hanging around that has Win XP on it for most of my radio programming. Maybe you have something else you can try? I don't have the radio yet so I can't help too much.
Bob
GrumpyGuard
NEWBERG
Bob, you are correct I didn't brick the radio. I was able to download and install the experimental version of the firmware. Now I just have to get Windows 10, the programming software, and radio to talk to each other so I can get the radio programmed.
radiotweester
Oregon
Here's the link to the newest release of the "experimental" for your radio's firmware.
http://pd0zry.nl/md380-fw/firmware-20170218-000001-221fcec3.bin
You'll still have to input CC and TS. It allows backlight dimming control along with the other MD380Tools.
The firmware on almost all of the sites is outdated since the 13.xx series new vocoder firmware came out.
This site is mostly for developers and coders of firmware, but there's some cool info as well.
http://github.com/travisgoodspeed/md380tools/issues
I'd also recommend the editor on VA3XPR's page over the stock software. You have to use the original TYT program to actually write info to the radio, but it's SO MUCH easier to enter (and copy) data. http://www.va3xpr.net/download/33544/
I don't know if it will make a difference with Windows 10, but here's the link to MD380 V1.32 You'll need 7zip or similar as it's a .rar file http://tyt888.com/uploadfile/upfiles/20161220133231.rar
GrumpyGuard
NEWBERG
This is a lot of information. I downloaded the code plug editor and I am using it to edit the code plug from the link listed above. The PNW DMR group has quite a bit of information and I am sifting through it. I hope to have windows 10 and the radio playing nicely with each other soon.
Thank you everyone for your assistance and information you have provided.
R-Rizzo
Portland, Oregon
I have a codeplug for all of Oregon, Most Washington DMR repeaters as well as the larger analog repeater groups if you still need one.
Sent from my Pixel XL using Tapatalk
GrumpyGuard
NEWBERG
That would be great. I downloaded one but I am not able to access anything.
I was finally able to get the radio and computer to transfer information and would love to get on the air.
cinsu
WT44
There are 2 nets tonight if you are able to get it setup, PNW 2 at 7 I believe and Oregon 1 at 8.
