Just curious if anyone is using a G4 or G5 to stream on Broadcastify......and if so....how are you feeding the audio to the input on the computer used to feed it, since there is no headphone jack ?
Yes - I am feeding a P25 system with Unication G5 - using the Amplifier/Charging base. Has been stable for several months.
Jason
You'll never get rid of the thump. You'll have to find a compatible BT receiver that does not have any beeps or unwanted noises. BT wont work while plugged into the charger base. You'll need to keep the Pager powered by USB all the time along with the BT device.
Have you tried turning the volume down as low as possible? I read somewhere here that the BT will not work with the unit in the charger. I am following this as I am considering a G4 for my feed.An update on this. A bluetooth receiver has the same thump sound when the squelch opens/closes, so I decided to stick with the amplified charger to provide the feed.
Thanks - I suspected as much. I've got the feed up with the G5 and the thump is definitely there. Sometimes it sounds like a delay before the audio kicks in. (Chesapeake Police). I'm also experimenting with different levels of attenuation.
I've ordered a BT receiver and will be trying that.
I am getting that thump from the amp base. How are you running yours now? Yours sounds great!
Thanks for any help
Danny
I did abandon the bluetooth solution and stuck with the amp base. I use an attenuation cable between the speaker output of the base and a USB sound card. It seems to help if I can turn the volume up on the base.
The thump isn't bad, but for some reason it does seem to cut out the first part (1/2 second maybe?) of some of the transmissions. Some side effect of going through the amp base and a USB sound card. I haven't spent time figuring out what causes that.
That’s a great idea. What dB cable are you using?
Thanks for your help.
I bought it a long time ago at Radio Shack, but I notice you can still find them on ebay:
https://www.ebay.com/i/381576852764?chn=ps&dispItem=1
I'm getting ready to throw my G5 on my feed (just waiting for the base to arrive). Question, with your base pumping audio into the feed, can you still use that front speaker too? Or, if you have the audio cable plugged in, does it disable the front speaker? I like to listen in live sometimes rather than through the feed and it would be nice if I had the option to just turn on that speaker.
I'm worried about that thump noise but.. a little bit of thumping is far better than the cruddy audio I have now with my Unidens.
I pray. I pray. That the G5 will be supported with alphatags in the feed someday.
I just ordered that cable. Hoping it helps some. I just put my G5 online and I'm getting that popping noise. Is this what yours sounded like before that cable?
https://www.broadcastify.com/listen/feed/9809/web
The popping is louder when listening from a mobile device. Ugh! This sucks. The simulcast prob is finally gone, now a new problem to face. :-(
