BCD436HP/BCD536HP: Uniden GPS/ Autolocate bcd436hp
BlueMoon2
Midlothian, VA
Once a yearI drive with my family from va to fl and like to listen to fire/rescue, police, dot, highway patrol, etc. To avoid having to program in every locality going up and down i95 n and south, I connect up the uniden gps to my bcd436hp with all the cables and go into the menu and hit 'autolocate'. It has been finding my current location while rolling correctly.
My question is, will the gps continuously update my scanner with my current location after the initial find OR will I have to continue to go back to menu and hit 'autolocate' again? My guess is that I will have to do the second option correct?
jonwienke
More Info Coming Soon!
VA
Do not ever use autolocate when you have a GPS. It is totally pointless. The GPS automatically updates the scanner location with far more precision than autolocate does, and it does it several times a second. It will override whatever the autolocate comes up with immediately. The scanner remembers the last location it got from the GPS. As long as you run the GPS at your destination, you don't need to do anything else.
marksmith
Anne Arundel County, MD
Autolocate DOES NOT USE the GPS. It tries to figure out where you are by listening to area RF and trying to find a system it knows.
It is a horrible way to determine where you are and will just do nothing if you connect a GPS.
As long as a GPS is connected, it tells the scanner precisely where you are continuously.
536/436/WS1095/HP1/HP2/996T/996XT/996P2/396XT/325P2/PSR800/15X/others
jonwienke
VA
And then use the GPS.
That's it.
Don't over-complicate it.
ofd8001
Louisville, KY
Yes, just connect the scanner and GPS device. Forget there is an Auto Locate feature. The GPS device will tell the scanner where it is and is the best way of doing so.
As an aside, Auto Locate is an alternative means of establishing a scanner's location. It only works with a Motorola or P25 trunked system that is in the database. What happens when you use the feature, the scanner monitors the system. It does some "internal research" with the stored database, noting the location associated with the system. It then says "I'm hearing this system whose location is X, so therefore my location must be X" and sets its location to be X.
marksmith
That's it.
Exactly. You should get confirmation from the scanner it is using GPS, and as you travel, periodically it will reload either the full database, or your favorites list, as long as the favorites list has location control YES enabled.
BlueMoon2
Midlothian, VA
Very helpful to know. Thank you guys. I know how to enable location control on favorites lists, but how do I do that with the full database when I'm not using favorites lists?
ofd8001
Louisville, KY
Location Control is "automatically" On for the full database. So there isn't anything you need to do (other than turn the full database on).
jonwienke
VA
It's always on when scanning the main database, because otherwise the scanner would try to scan every frequency and trunked system in the US and Canada. That would probably take an hour or more for the scanner to cycle through, and would probably crash the scanner.
W5RGP
Charlotte Tn
It only works with a Motorola or P25 trunked system that is in the database. be X.
Wrong
As long as any systems coordinates are in the database it will work doesn't have to just be a p25 system
marksmith
Every conventional frequency in the database has location information.
Location control works on EVERYTHING
kma371
Everything will at least default to the county it's located in/assigned to.
jonwienke
VA
Wrong
Autolocate only works on P25 systems, because the NAC works reasonably well as a unique identifier for the system, and P25 control channels broadcast continuously. There are enough NACs (4093 that are not reserved for system functions) that hearing a system with a given NAC has a high probability of meaning you are in range of one and only one system.
DMR systems are not used for autolocate because there are only 16 color codes, and the odds of picking the correct location based off "I hear a DMR system using color code X" is less than 2%.
But do not confuse autolocate and Location control. Autolocate guesstimates a scanner location based off p25 NACs that the scanner can hear. Location control enables and disables systems and departments based on where the scanner thinks it is. GPS gives the most accurate location, followed by ZIP code, then autolocate.
The only time using autolocate makes any sense is when you don't know your zip code, and don't have access to GPS.
ofd8001
Louisville, KY
Well, if I'm wrong, so is the Uniden manual on page 24.
Auto Locate – The Auto Locate feature works by trying to monitor any Motorola or P25 system in your area that is also in the Radio Reference Database.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You're correct, jonwienke is wrong.
It's looking at System ID's not NAC's.
