Kenwood Jitter Buffer / Network issues
KI4UVJ
I currently run a 2 channel, 3 site (Central, East and South) Kenwood Nexedge conventional voter IP system that is linked via microwave (airmux 400's). The East site has both RX and TX for both Channels, Central is channel 1 TX and South is channel 2 TX. Channel 1 voter is in central site, channel 2 voter is at south site.
The problems I'm having is that the East site is about a 5 mile link, and I'm getting broken/garbled audio, out of that transmitter. Not all the time but most transmissions have some garbling, seems to be more prevalent when they de-key.
The link signal strength to and from the East site is around -64 on both MW antennas, they are the flat panel on both sites. I have already been told that this set up is pretty much at it's threshold, and needs to have parabolic dishes. We are moving or adding another transmit site in the next couple months but need to square this away.
The links are running at around a 5ms latency with no packet loss to the east site, I use PRTG to monitor the network.
About the only setting I see that might help me is the jitter buffer. Can someone help me out with how it works in this situation? (yes I've read the 129 help topics).
I guess my main question is that should the jitter buffer setting be the same across all repeaters? Or can I mix and match to get the best performance? Would increasing the minimum or maximum be best?
I do have complete control over the repeaters, I do not have any access other than observer on the links.
Thanks in advance.
kd4efm
Florida
jitter buffer should be the same across all sites.
I have found 8 is pretty good. I work on a 9 site single channel network and that's what I have
the buffer set to.
KI4UVJ
Hey thanks for the reply. The buffer on the 810's (should have stated this prior) are set in steps of 80ms.. Default for the buffer is 400ms max and 80ms min.
I painstakingly sat and adjusted this until I began to hear improvement over several days and found a happy spot for the EAST TX which is max buffer is set at 160ms and the min is turned off. Finally got rid of the majority of the garbling.
Thanks!
kd4efm
Florida
Congrats. Good luck with it.
Sent from my SM-G935P using Tapatalk
