APX Unified Call List Import from CSV
N1GTL
CT
A friend and I (mostly the friend) have come up with a program that will automatically create a Unified Call List XML file suitable for importing into an APX radio. Basically, a customer can provide a spreadsheet with the proper information and in about 2.3 seconds, this program will take the spreadsheet and create the XML file.
We have done this on the premise that there are 2 conventional systems created in the APX CPS and they are the default names (Cnv Sys 1 - ASTRO & Cnv Sys 2 - MDC).
The CSV file needs the following in order:
Column A: Contact Name
Column B: MDC ID
Column C: Astro25 Conventional ID
Column D: Astro25 Trunk ID
Not all fields are required. If only an Astro25 Conventional ID is needed, columns B and D can be blank.
If anyone out there has a spreadsheet with a lot of contacts and even one of the ID columns, I'd love to get a copy and test it out and troubleshoot anything that may have been missed. I'll move the columns around if necessary. I just don't want to create a spreadsheet with 200+ contacts; I'd rather have a real life list. I'll even provide XML files back for importing into your APX code plug.
Please private message me for my contact information.
Thanks,
Jim
N1GTL
CT
It's still a work in progress. Validation is being added. If any invalid characters are entered, it will report the errors. Likewise if the contact name is greater than 14 characters, it will report that back. Its also going to make sure there are not duplicate contact names.
GTR8000
NY/NJ Database Guy
BEE00
The APX UCL allows for up to five IDs to be assigned to a single contact name, so take that into consideration for any validation routines. Simply preventing any duplicate contact names would be counterproductive.
N1GTL
CT
If I duplicate a contact name, it gets highlighted in red. I understand numbers may be duplicated but I don't thing the contact name can. As far as the IDs I'm just making sure an MDC ID is nothing but hex values and digital IDs are numbers, not letters and no more than 8 digits.
GTR8000
NY/NJ Database Guy
BEE00
You cannot have duplicate contact names in the UCL itself (that is to say, when looking at the list in CPS all contact names must be unique). However, since you can assign up to five IDs to a contact name, it wouldn't be unusual for the spreadsheet or csv used for importing to contain rows with duplicate contact names. (Note that the limit of five IDs per contact name takes into account the combined total of different types of IDs assigned; MDC, P25 Conventional, ASTRO 25, etc.)
I'm not sure why you had difficultly making sense of adardam's UCL Builder, it's pretty straightforward. That being said, an "offline" program that accomplishes the same would be handy, should his website go belly up. I'm watching this thread with interest.
N1GTL
CT
I still have not gotten any senders offering a spreadsheet for me to test. I am sure, somewhere out there, someone must have a spreadsheet with a few hundred contacts and MDC, Astro25 Conv and/or trunked ID's. I'm offering to proved the XML for nothing. I typed in 15 contacts with a mix of the above systems and it worked. I have not tested it with the error checking features.
N1GTL
CT
I got your file. The first problem was 55,000 records which is way above the limit of an APX UCL. No biggie, I just deleted a bunch.
The second issue I ran into is duplication of call signs. The UCL must have a unique contact, no duplicates. One of your contacts had 7 DMR ID's. The program did not like that. There was also one row with no call sign. Again, that's an issue.
What you sent was exactly what I wanted so I can test things out and create error checking. The program will report back unusable values so they can be corrected.
Thank you. I will be working on this more tonight.
sfd119
I'm just not sure why you're trying to reinvent the wheel here? The UCL import tool I linked above works flawless and has been used by a lot of people.
N1GTL
CT
I couldn't figure it out and I have a strong enough programing ability to write my own.
xcrownvicx
New Jersey
Column B: MDC ID
Thanks,
Jim
Hi i'm trying to add some more contacts into my APX8000 radio but i'm having difficultly understanding the UCL builder. I exported the unified call list to cheat off of it but i'm still having trouble. My private message is not working.
N1GTL
CT
Exporting the UCL will give you an XML file that may be tricky to figure out unless you've done and understand some level of programming.
xcrownvicx
New Jersey
I do have a very good understanding with radio programming. Im really good with analog conventional programming but not so much with the trunking. Would you be able to help me through it.
xcrownvicx
New Jersey
I was referring to COMPUTER programming.
Yes I do have skill in computer programming. Would you be able to assist me with this. I have tried for many hours to try and figure this out. I really want this to work out for my company and others to come in the future.
