XTL5000 keypad beep volume?
phillydjdan
I recently aquired 2 XTL5000 mobiles with W5 heads. I can't seem to find any settings in CPS that let me adjust the volume of the keypad beep. It seems like it is a fixed setting, but the volume beep changes with the volume. Am I missing something? I don't want the beep to be so loud when I am changing channels or whatever. Thanks in advance!
phillydjdan
Mike, I went back in and did some poking around. The setting that had me was Minimum Alert Tone Volume in the Alert Tones tab. It had been set to 100 (probably the default). I changed it to 25 and enabled the Volume Adjust Tone Offset check box and now it appears to be doing what I want.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I checked some old codeplugs and they were set to 100 as well. Sounds like a default.
phillydjdan
That's what I figured. Thanks. Now to try and hunt down an O5 head upgrade lol...
mikewazowski
Staff member
Forums Manager
Oot and Aboot
What do you need? A control head sync file?
Not sure what the latest is but I did have a collection at one point.
phillydjdan
Yeah I guess I will need the file at some point. I am trying to track down the parts to do it but once I do the file will come into play. Can you email me? Its philly.djdan at gmail...
