VX231 not talking to BAOFENG
Cigarbufff
Hello I was hoping someone could help me on an issue i am having. So basically I have 4 vx231's that are all programmed on the same freq (frequency detected on uniden bearcat as 471,325) they can all RX and TX amongst each other but when i program my baofeng to the same frequency nothing happens. I cannot RX or TX between any of the VX231s and the baofeng.'
Any help would be appreciated.
Thank you
cmjonesinc
Is the frequency an input for a repeater by chance? I think 471.xxx is in the uhf tv band in the US. However I'm assuming you're not in the US because of the use of the frequency and the use of " , " as opposed to " ." With frequency description. Knowing your country would probably help so we can look up a band plan and see what the standard use is for.
Cigarbufff
i am on Ontario Canada. Also my scanner picks up the signal under multiple freq. but 471,325was the clearest. Hope this helps thank you
teufler
ST PETERS, MISSOURI
Do you have a monitor button on the vx213. One that temporarily opens the squelch. If so , with your other hand, key the Baofeng. If this works, you are transmitting, and you have a pl tone, or ctcss problem. Either its a ctcss of maybe a dcs code setting. Not sure what scanner you have. Some will do a tone search. Also maybe the 471.325 transmits 5 mhz higher, its a repeater. If so, set the Baofeng to 471.325 for receive and 476.325 for transmit. What you have found, indicates you are close to working this out.
cmjonesinc
The signal may be an image of another frequency. I'm not super familiar with the band plans up there. But I know my uniden has had some issues with frequencies imaging over to other bands. It very well could be on 471.325 but since it's showing up on multiple frequencies check the 150-174 MHz area and see if it shows up there. If you have the vertex very close to your scanner trying to figure out what frequency it is on that can definitely be the cause of a overload to the scanners receiver. But if you're miles away from the transmitter it very well could be in the frequency range you're seeing it in. Sorry if that sounds like a mess, but I'd give the vhf band a scan.
teufler
ST PETERS, MISSOURI
cmjonesinc: suggested you are receiving am image. Can you tell by looking at the Vertx radios, are they uhf or vhf models. Take the battery off, there is usually a label on the inside. Also unscrew the antenna and look on the bottom of the antenna. Sometimes there is an indication on what the antenna is for. Lastly, sometimes uhf receives are harmonic of a vhf frequency. Usually it is 3 times trhe vhf frequency, try the Baofeng at 157.105. If ,the radio is desensing the scanner, if somebody can monitor the scanner for you, walk outside, go to maybe a basement room or upstairs room. Thia will reduce your desensing problem.
Cigarbufff
Wow thank you both for that heads up. Some of that info is above my head at the moment but I willl definitely try your suggestions,
cmjonesinc
I knew someone with more experience with harmonics would chime in. I know of it, but I can't direct anyone in the appropriate direction. But as teufler said, check out 157.105. That sounds way more of a common frequency than anything in the 471 band
teufler
ST PETERS, MISSOURI
This is a report extract from all frequencies in OntaRIO PROVIENCE. It appears like 471.325 is a "birdie" or your scanner is detecting something but not a signal. You will notice the frequencies jump from 470.1492 to 476.XXX. Canada appears to have that missing 5 mhz to something or someone else. Maybe take the scanner to a frequency counter and get the answer.
469.7125 0
Ajax Durham Town of Ajax TwnAjax
FMN BM Public Works 469.7125 0
Hospitals Huronia Regional Centre Statewide Paging HRH Paging FM
Hospital
469.7125 0 CKR829 Woodstock Oxford Woodstock District Community Complex WDCC
FMN BM Public Works 469.9125 0 VEK281 Thunder Bay Charity Casino Thunder Bay Statewide Casino Casino
FMN BM Business
469.9375 0 XJH397 Countywide Essex Fire and Rescue Service Dispatch UHF Link EFRS-DispUHF 123.0 PL FM BM Fire Dispatch 469.9625 0 VAZ320 Business Woodstock Statewide Firestone Textiles Bridgestone Firestone
FMN BM Business
470.05 491.5
Media Television Statewide A Channel Control Room IFB CKVR 82.5 PL FM BM Media
470.05 491.8 XLD202 Media Bell Media Queen Street Bureau Statewide CP24 Wireless CP24Wireless 82.5 PL FM RM Media
470.1 492.525 VEF871 Media Bell Media Queen Street Bureau Statewide CP24 Wireless CP24Wireless 82.5 PL FM RM Media
476.05 497.8 VEF998 Media Bell Media Queen Street Bureau Statewide CP24 Wireless CP24Wireless 82.5 PL FM RM Media
Cigarbufff
ok so its ghosting then through something else it looks like?
should i just sweep the whole band?
Cigarbufff
New Finding
Just a little bit of background here. I am using a Uniden Bearcat 246xt to scan the vertex radios. I scanned them once again today and I found that 459.2250 dcs331 works on the baofeng and the vertex. But here is my dilemma. If I talk through the vertex radios I can hear it on the baofeng. But if I talk through the baofeng the vertex Green lights light up but I cannot hear any transmission.
I GOT THEM TO WORK WOOHOOO I had to go into T-DCS and it was trial and error from that point trying every possible option. But now they work! YESSS Im soo happy
Thank you soo much for all your help I greatly appreciate it
ROB
gary123
the Canadian Ontario band plan for 470+ Mhz matches the USA band plan. The 471 freq if that is where the units actually are is allocated for TV.
I suspect a birdie as well. If he has a close call scanner he should be able to get a good hit on it if he takes the antenna off the scanner while TXing near it.
