just got my G5V today
parma,ohio
just got my G5V today and have a problem with the speaker will not un-mute
the problem i have isi can't seem to UN-MUTE the speaker for trunking with out the alert tone been working on it for a few hours i'm lost.pager does scan just no voice the speaker on the display has a line threw it.if i hold the side monitor button works fine must of screwed something in the setting.
Com-Tech51H8
bureaucratic absence of presence.
BEE00
when your in the pps and setting up your zone there should be an option for push to listen select no. and to fix the channel alert its a drop down menu in the same location as stated select silent
Thunderknight
Bletchley Park
when you change each channel it talks it their a way to stop the voice channel Announcement to silent?
Yes. It's a drop down near the top of the channel knob selectors. I'm not looking at PPS right now, but I think it's just to the left of the selection for the scan type.
APX8000
Sarcastic Member
AES-256 secured
The little thing really pulls in trunked systems. You're going to really like it. Once you get the PPS down LOL
parma,ohio
been working on the code plug for a few months to program this G5V works GREAT no more XTS-2500 never did take it out of the house did not want to answer questions about it lol now i'm LEGAL
parma,ohio
back lighting
i think this pager when you turn up or down the VOL it use to light up and show you with the back lighting on? now i have to hit the top side button before i turn it up or down in VOL? sure is a lot to learn in this G5V
troymail
Silent Key
When I adjust the volume, it's a bit slow to light up if at all. What I've found is the more programming you have onboard, the more sluggish user interaction becomes... maybe a fix will come a some point but it's a small price to pay for the great reception.
parma,ohio
one more question i have 21 zone's now i have Z22 is user define and 23 is CH.Setting how do i remove them in the zone line up? your answer eorange works GREAT on both systems i use a Astro Plus for my cleveland fire base radio this picks up WAY before my base does
eorange
♦Insane Asylum Premium Member♦
Cleveland, OH
Ok, so I guess there's 2 questions:
1. Do you pick up more, which is yes.
2. How about the LSM distortion? Do you hear any?
IAmSixNine
Dallas, TX
I have noticed on mine if im parked on a conventional channel or scanning conventional, the unit kind of goes into a sleep mode where turning the volume knob doesnt light up the screen.
However if im on a trunking channel or scanning trunking and adjust volume then the screen does turn on. Probably a bug but its how i have been used to the pager operating.
parma,ohio
IAmSixNine Signal-Zero told me its because of how zones are programmed in it and takes time to catch up lol other than that works GREAT
IAmSixNine
Dallas, TX
My doesnt do it late, it simply does not do it at all.
As i mentioned before with trunking personalities adjusting volume does light up screen.
Adjusting conventional personalities screen never turns on.
That to me does not indicate a lag due to overloaded processor.
IAmSixNine
Dallas, TX
Could be a placebo affect for me. The trunking systems are also busier then the conventional i monitor. So with the trunking having more activity the unit is not going into a deeper sleep mode like its doing on conventional.
Ill test it with a single channel trunking thats not busy and see if it stays off when i adjust volume.
