Motorola 800 Portable Stubby
evfd1625
Indiana
Does anyone know if the older 800 stubby quarter wave antennas "work" on the 700 mhz frequencies? I've heard this antenna touted as a wideband antenna, covering 900 as well. However, I'm not sure if it's meant for 700 as well. The newer units with the same PN have new stamping showing 700/800 on the rubber now. I know performance wise they are less than ideal, however I carry my radio usually in my vest carrier pocket. The half wave antenna is tempting to use as a chew toy now. Haha
Sent from my SAMSUNG-SM-G891A using Tapatalk
The older stubby 800 antennas we used on our MTS-2000's were 800-900MHz. I put on on my analyzer and that's where it swept well.
They were a bit high on 700MHz, but for receiving use, probably fine. For transmitting, you might be better off with a 700MHz specific antenna.
evfd1625
Indiana
I have them on a couple of PSMs that I rarely use. The state is all 800 at the moment, however I think we might have 1 site coming up with 700 frequencies, then there are the 700 interop frequencies that are in my radio, but never used. I'm not super concerned, but wasn't sure. I'll order a couple of the 7/800 stubbies and switch them out with the older ones as time goes by. Thanks
INDY72
Indianapolis, IN
700 is part of the 800 band. It is the lower split.
Sent from my LG-K330 using Tapatalk
evfd1625
Indiana
The ones I have are white base iirc. One of them came as a kit from a PSM made in 2002, well before 700 was even vacated.
