Well, thanks for the replies. This drill bit has good reviews including a number of posters who said they used it for NMOs. My plan is to sacrifice a baking tray and practice a few times. Then I'll see how the mount fits in the baking tray. The antennas are going on the trunk, so no worries about any headliner.
I happen to have that exact same hole saw sitting in my garage. I have the official Antennex depth limiting NMO hole saw, too.
I also happen to have a set of digital calipers accurate to 0.0001 of an inch.
So take the previous comments with a grain of salt. There is some excellent advice above, and then there is the "me too" crowd.
I'll 100% agree that using the correct tool for the job is the right way to do it.
I'll also 100% agree that if you are doing a single install, not going into the installer business, you probably don't need to buy the top dollar hole saw.
The truth about hole saws is that they make round holes of a specific size. The tooth spacing on the saw part sort of dictates what sort of material it's going to work best in. Finer teeth cut slower, but work better in metals. Coarser teeth cut faster and are usually good in softer materials.
The "magic" behind the official NMO hole saws is that they have a couple of handy features:
1. Depth limiting. That helps reduce the chances of damaging headliners.
2. Fine tooth blades. Takes a bit longer to drill the hole, but does so in a more controlled fashion.
3. Replaceable saw blades. No need to replace the entire hole saw.
4. Some have a feature that scores the outer part of the hole on the exterior of the vehicle to help with grounding.
So, back to size….
If you have a hole saw with a maximum outer diameter of 3/4's of an inch (0.7500), it's going to make the right size hole. Doesn't matter if you bought it from a company that caters to radio installers or the local hardware store. 0.7500 = 0.7500. The source of the hole saw doesn't magically make it drill larger holes.
The 3/4" "Trade Size" statement above is true, but that isn't what you have. In the electrical industry, they'll sometimes call a hole saw or punch 3/4" trade size when it's designed for 3/4" conduit. It's actually 7/8" because that's the size of the threaded fittings. That can be an issue if you grab the wrong thing, but in this case you didn't.
So, I measured my "official" NMO hole saw, and it was 0.7475 inches in diameter. Just shy of 3/4". I've installed a lot of NMO mounts with this hole saw and I have never had an issue with that 0.0025 difference.
I then measured the DeWalt 3/4 inch hole saw. 0.7450 inches in diameter. A bit smaller than the NMO saw, but likely it would work just fine.
The teeth are a bit more coarse on the DeWalt hole saw compared to the Antennex hole saw.
I would absolutely prefer the Antennex saw, but that's easy to say because I have one sitting there ready to use. It makes the right size hole and won't go too deep.
But, the DeWalt hole saw will work just fine for what you are doing. It's going to make the right size hole. You don't need to run out and spend $40+ on an "official" NMO hole saw for one install or to make a bunch of strangers on the internet happy.
Just take your time and measure twice.
