USB ribless programing cable available?
N7AS
Prescott Valley, AZ
Is there a USB ribless programming cable available for the MTS2000? Or could I just use a readily available DB9 ribless cable along with a USB to serial cable? Which would be the best method?
toolman60
N7AS,
You may be able to get by with the USB cable. Some people have good luck with them. Some people have good luck with the USB to serial adapters.
Me I prefer to use the old school standard rs 232 to rib or radio. To many chances for a hiccup and make a nice doorstop or paperweight with all the extras inline but ,that's my preference as I have to many antique pc's in house with real serial ports.
Good Luck
Tim
N7AS
Prescott Valley, AZ
I use a ribless cable with the DB 9 connector to a USB to serial adapter.
Sent from my HTC One A9 using Tapatalk
My PC is Windows 10 PRO 4.0GHz. Is it too fast to run CPS or should I try to find a Netbook just for programming? I don't want to spend alot of extra money.
N1XDS
ÆS Ø
I'm running a FTDI USB to Serial DB-9 cable and serial DB-9 to cable for Motorola CPS for DMR/Astro P25 on Windows 10 Pro 4.3ghz and both CPS runs fine on my computer. I say try it out to see if it works or not its the only way you're going to know for sure.
Project25_MASTR
Millennial Graying OBT Guy
Texas
A 64 bit version of Windows won't work with MTS2000's RSS. Even though APX and TRBO CPS officially support Windows 10 now…they still don't run extremely well in a Windows 10 environment.
cmdrwill
So Cali
Check Kawa Mall for the Jedi SERIAL cable, the MTS2000 windows software does not work well with USB, as it was written way before USB. The MTS2000 Radio CPS Ver 02.03.00 is the current Windows version.
BTW RSS is DOS only. And our Licensed RSS runs just fine on fast Pentium computers, in DOS......
kawamall
RIB-less Programming Cable Motorola XTS3000 HT1000 MTS 9 pin serial. $16.90
n3obl
Ø
PA
Just so you know Motorola does not make an Oem rib less cable. That would have to be a knock off.
cmdrwill
So Cali
Cant be a knock-off as Motorola never made a one piece serial programming cable for Jedi radios. Kawa Mall has the best serial cables.
N1SQB
Somewhere On Earth
I second that. I get all my ribless cables from him. Never had a single issue.
The MTS 2000 ribless cable also programs the XTS3000 portables. I use a tough book with a serial port running XP 32 bit.
Manny
N7AS
Prescott Valley, AZ
Is your Windows 10 PC 64bit or 32bit?
Project25_MASTR
Texas
I'm running 64bit with no issues. :D
Astro 25 CPS or Astro Saber XTS3000 CPS?
TRBO officially supports Windows 10 now (as does APX) though there are still a couple of quirks for a few uncommonly used features.
N1XDS
ÆS Ø
Astro 25 CPS I'm using a XTS 5000 UHF.
