Road trip ... (or "What did I learn today?")
troymail
Silent Key
Traveled to various areas today on a big road trip/loop. Learned a couple of things with my G4...
1. Use caution when entering WACN, SYSID and particularly RFSS and site values. I was getting "out of range" messages on multiple occasions and systems over the past few days and it turns out that I was entering RFSS and site information in decimal when the input screen was expecting HEX. I really ought to know better....
2. I learned for the second time now that you cannot trust the information on RRDB that most people do not use. A year (or more) ago, I learned that there's alot of system/site location (lat/lon/range) data that is bad and/or not what you'd expect. Today I found a case here the RFSS/site information for a system was incorrect on RRDB and once again, the G4 just kept reporting "out of range" (it was not - the G4 just didn't find a RFSS/site value pair on the active frequencies/control channel that matched what was programmed).
For Unication: it might be better to provide a different message (other than "out of range") if a CC in the programming is detected and active but the system characteristics (SYSID, WACN, RFSS, site) do not match what the radio extracts. It would have helped me solve both of the above problems much more quickly.
KevinC
Junior Radio Guru
Super Moderator
Home
This bit me as well. Not blaming Unication or RR, but as you said, it's not something "scanners" use so the database may have lots more of these errors we don't know about.
guyiv
Lower Delmarva
I usually just put the FFF/FFFF(Wildcard) in so it uses whatever site information it finds on that CC.
troymail
Silent Key
It's an option - something I'll use in areas I haven't been in before.
However, while it isn't likely, I think that can cause issues if you have alot of frequency reuse in your area.
It also doesn't work if you're trying to control which site you're trying to monitor.
sparklehorse
Portland, Oregon
<snip> I learned for the second time now that you cannot trust the information on RRDB that most people do not use. A year (or more) ago, I learned that there's alot of system/site location (lat/lon/range) data that is bad and/or not what you'd expect. Today I found a case here the RFSS/site information for a system was incorrect on RRDB and once again, the G4 just kept reporting "out of range" (it was not - the G4 just didn't find a RFSS/site value pair on the active frequencies/control channel that matched what was programmed).
I have observed both of these issues with the RR database in my area as well. 'Trust but Verify' has become my RR mantra.
RRR
OFFLINE
USA
Negative. I have had NO luck doing that with my G4, if the WACN isn't correct, I get "Out of area" every time. The F's do not allow me to get a lock on any system I try to monitor.
troymail
Silent Key
There must be a different problem with the system, radio or programming. Is your G4 receiving any P25 trunk system?
I've used all F's several times including on several different systems this week. It's pretty much how I figured out that I was being dumb and programmed one system RFSS/site as "10" and "10" but it should have been "A" and "A".
On a trip a few weeks ago, I even created a wildcarded (all F's) system and enabled "Full Spectrum" to search 769-775 and 851-866 for any P25 system. The configuration found several systems (some that baffled me at first) and even tracked the sites of two different state systems as I drove through the state.
It does work.
parma,ohio
My G5V
I'm in cleveland and last weekend went to Jackson Michigan i did enter all CCs from Cleveland to Toledo and monitor the Ohio Turnpike State Patrol it worked 100% never missed a beat.
KevinC
Junior Radio Guru
Super Moderator
Home
May be a dumb question, but did you enter FFFF for the WACN or FFFFF?
