Any Ohio counties part of MABAS?
QDP2012
Good morning all,
In the RR Wiki, some Ohio counties' pages contain Mutual Aid Box Alarm System (MABAS) Fire Tone Out information.
In the second paragraph of the Mutual aid (emergency services) Wikipedia page, Ohio is not listed as a MABAS state-member. A quick Google-search did not find an Ohio-MABAS site.
<strikethrough>According to MABAS-IL Members By Division and County (.pdf), "Ohio Fire Protection District" is in MABAS Division 57.</strikethrough>
(1) How do MABAS and Ohio relate? Are any of the Ohio counties officially part of MABAS?
  • If so, which?
  • If not, are the Ohio counties responding on MABAS alerts only due to individual mutual aid agreements with adjacent counties, but not responding due to a MABAS agreement?
(2) Are there other states which are/might-be part of MABAS, but which are not listed in the above-linked Wikipedia article?
Thanks for any clarity that can be shared,
QDP2012
Thanks for the reply,
According to the Wikipedia article, it is a multi-state or large regional system..
"MABAS (Mutual Aid Box Alarm System) is a regional mutual aid system, headquartered in Illinois, with 1500 member fire departments in Illinois, Indiana, Wisconsin, Iowa, Michigan, and Missouri."
In the RR Wiki, MABAS FTO information is listed in the Cuyahoga Valley Region Cuyahoga County (OH) and Geauga County (OH) pages, which are in the NorthEast quadrant of Ohio, not near either Illinois or Indiana or Michigan. Which is why I am curious about how/if Ohio and MABAS relate.
Never heard of it - Google says it's in Illinois.
https://usfiredept.com/ohio-fire-protection-district-17066.html
or more info here
http://fire.wikia.com/wiki/Ohio_Fire_Protection_District_(Illinois)
City: Ohio
County: BUREAU
State: IL
Zip: 61349-0351
Thanks. My first post didn't catch that the the "Ohio FPD" is in IL; that was my mistake with the Google-search; so, in regards to the primary question, let's ignore my search-mistake about Ohio FPD. And, Thanks for catching it.
Still, the FTO data in the RR Wiki for those two Ohio counties leaves me wondering about why those counties would be using or caring about MABAS fire tones.
Thanks,
I'm thinking MABAS in NE OH is a generic term - maybe or maybe not associated with any regional outfit. I've heard the term MABAS used locally.
wmlovell
Aurora, OH
Ohio has a State Emergency Plan for larger incidents that gets activated after the local Region's response plan is overwhelmed. These incidents then get coordinated as a State response plan.
https://ema.ohio.gov/EOP_Overview.aspx
MABAS is a pre-selected list of agencies to respond for a given situation based on a tiered response of alarms. The larger the incident, the farther on the alarm list that will get requested. ...and response is generally determined by geographic location or specific equipment available, sometimes with staffing considerations also in mind.
Local FDs can have their own individual MABAS plan ...or it could be County-wide. Some of the agency groups form an association, of sort, to ensure all of the participating agencies have the same type training and procedures, etc.
These pre-determined plans ensure that sufficient manpower/equipment gets dispatched to the incident freeing up the Incident Commander to other tasks. (example: 2 Engines, 1 Ladder, 1 Chief and and ambulance additional to scene). It also reduces the possibility for Dispatch to miss one of the requested pieces as the list is already available to them. In better arrangements, all or most of the various departments can be notified simultaneously accelerating the different agency notifications.
The Box Alarm System comes from the days where Pull Box Alarms were located on different corners in larger municipalities. When that alarm box was physically pulled, response was sent for the greatest hazard in that geographic location. When that Incident Commander arrived to see the hazard was actually on fire, they would notify (by the telegraph located inside the pull box) and a designated additional pre-determined response would get sent.
911 replaced the pull boxes and commanders now use radios. ...but the old acronym for pre-determined response list still exist.
I hope this helps to what you were looking for.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
One other thing to note is that MABAS is a locally-used term; it's not statewide. In Central Ohio a similar system is simply known as Automatic Response or Mutual Aid (although dispatchers who don't really know the difference often get them mixed up or just call it all Mutual Aid), and the response assignments are defined by Run Cards.
Around here, Automatic Response is basically limited to agencies within the same county (or within one or two jurisdictions of each other if in adjacent counties), while Mutual Aid casts a much wider net. Basically, an agency would respond automatically as part of the first alarm assignment under an automatic response agreement, while mutual aid required that the requesting agency have units on the scene. The distinction between the two has gotten somewhat blurred over the years, but is still essentially the same in practice. The State Emergency Plan would be considered Mutual Aid.
Also, the response area for a given department can vary based on local agreements.
QDP2012
Edit:
Thanks for clarifying that in Ohio, the term "MABAS" is only used as a local-term to reference locally-defined mutual-aid, or possibly regional mutual-aid within Ohio only, and is entirely different and separate from the multi-state MABAS that is headquartered in Illinois.
Thanks again!
DualReverse
Sort of, except that for SERP activation, monies for reimbursement would become available under certain conditions.
To the OP, MABAS (the organization) reaches into Illinois, Indiana, Wisconsin, and I believe Missouri. But, like Tom said, in Ohio, there is a strong MABAS-like culture along the north shore. In greater Columbus and to an increasing extent Cincinnati, mutual and automatic aid response where units regularly cross jurisdictional lines is pretty common.
Under statewide response, it is assumed that standard local and regional mutual and automatic aid is exhausted. The requesting agency would need to provide a listing of the agencies already committed so those agencies aren't tapped again for more resources. For those communities that border another state, it is assumed that by the time the plan is activated, resources that would normally be available to cross state lines, would have done so already.
