Why does my feed sound like this?
ProScan
Software Provider
Ontario, Calif.
About every 30-45 minutes my feed will go completely unintelligible. It will slowly get worse for about 2-3 minutes then go back to normal.
Anything I can change to stop this?
Here's an audio sample:
https://streamable.com/5lm8m
It sounds like you are overdriving the sound card. Is the scanner volume way up? I would turn it down and turn up the sound card input.
J
jlmaddencc
Guest
The noise on the line is the Sound Cards Line In Volume turned way up, turn it down and turn the Scanner's Volume up.
Nate1n22
Muskegon, Michigan
That's wierd, sounds like bleed over. Can you tell what agency is talking?
I just have 1 agency being broadcasted.
What are you using to broadcast your feed?
Nicecast.
The volume is about a 1/4 past completely muted. I'll try lowering it.
Coolant113
Warren County NJ
I use to have issues similar to this when I use to use NiceCast. Nothing was ever explainable for as to why the issue was occurring. NiceCast has a mind of its own.
