Il state police and radio shack pro 197
shortbus91
Jerseyville IL
What talk groups are phase 1 I was under the impression it was all phase 2.
And is it The Illinois State Police and many other agencies have switched to the statewide StarCom21 digital trunked radio system. The system operates on the 700 and 800 MHz.
mws72
Quad-Cities (IA-IL) USA
In the list you can see D (digital), E (Encryption) and T (Phase 2 digital)
yours should only hear the D listed
shortbus91
Jerseyville IL
Im also new to trying to program my own scanner is there any kind of helpful information to look at to guide me through the process that you all are aware of.
shortbus91
Jerseyville IL
The directions that came with this book does not help at all. Very little information.
When it comes to hex codes like the photo I added why can't I find that I can find where the Nac code goes.
And do you know is this a talk group system.
TGP
Metro East, IL. St. Clair County
Yes it is a TG system
Don't worry about hex codes for now.
Program the control channels for your location .
Then add Talk Groups for what you want to hear.
Did you search U-Tube like I said?
There are Ton's of radio video's on there that should help you
Understand.
Tom
shortbus91
Jerseyville IL
You tube videos kinda explained it but left out hex info.
As you can see by the photo I added the other day it said hex and doesn't give frequencies.
I'm trying to find mine I'm in the town of jerseyville
TGP
I think ISP D18 is what you should be programing.
And I'm not good at GRE programing myself.
The system in the radio has to be correctly set up
All I can suggest is to read and watch until you understand it better,
It's not like the old days of just entering Frq. numbers.
Dispatched by ISP District 11 (Collinsville).
DEC HEX Mode Alpha Tag Description Tag
17009 4271 D D18 Dispatch A Dispatch A Law Dispatch
17010 4272 D D18 Dispatch B Dispatch B Law Dispatch
17024 4280 D D18 Detail A Detail A Law Tac
17025 4281 D D18 Detail B Detail B Law Tac
17034 428a D D18 IREACH IREACH Patch Interop
17040 4290 D D18 ISPERN ISPERN Patch Law Talk
17046 4296 D D18 Local Patch Local Patch Interop
17052 429c D D18 Car-to-Car Car-to-Car / Speed Traps Law Talk
17058 42a2 E D18 DCI Ops Division of Criminal Investigation Law Tac
17081 42b9 D D18 Intercom Intercom Law Talk
Tom
shortbus91
Jerseyville IL
Okay so now I got the part about dec I type that in and it automatically does the hex for me but I still can't get it to come in.. Grrr small steps lol..
skinnyb82
Galesburg, Illinois
The manual straight up sucks. I didn't even get a manual with mine but I've seen the OEM manual, not helpful. Referenced the "Easier to Read" manual for Pro-651/652/106/197, WS1040/1065, PSR400/500. That one is extremely helpful.
I use my Pro 197 to pick up Starcom21 on a daily basis. Programmed it using PSREdit 500. Gotta have an FTDI cable but it's worth it. Use the 30-day trial period for PSREdit and/or Win500 to program it initially, then you can tweak the system even if you choose to not buy the software.
Sent from my VS987 using Tapatalk
shortbus91
Jerseyville IL
Okay so I figured out how to program the scanner by using the codes here.
I found out that the control channel is. Red and blue is the so called 2nd code then I put the other 2 in and it worked.
My next question how would I find out what troopers that are in my town at any given time use what tower.
Do you think the one I put into the scanner would be the right one.
Or would I be better to use another one. I do know they cover a lot of ground so wasn't sure. Also is there a list of officer numbers of some kind for a reference key to try to figure out who I'm listening to. I've heard 3 Frank and other named while listening.
I've even picked up Springfield area. So any help will be greatly appreciated.
Thank you.
skinnyb82
Galesburg, Illinois
Red is the primary control channel, blue is the alternate. Those are the only two you really need. I program mine for multi-site, but if you wanna monitor the Springfield tower, need to program in the tower primary and alternate CCs, talkgroups for District 9 (and 14, 20 since Springfield dispatches Macomb and Pittsfield now). With ISP Troopers, each mobile and portable has its own radio ID (as does any other P25, DMR, etc radio) and is usually tied to individual cars. Prefix for Zone 2 mobiles (car) is 200xxxx and 210xxxx for portables. I simply listen to my local District and record RIDs. Have compiled quite a list of D7 Rids. Your scanner will display the radio ID that is transmitting, assuming you have the right settings to display the RID. Here's a link to the wiki page for Zone 2 radio IDs.
http://wiki.radioreference.com/index.php/IL-STARCOM21-RID_6
shortbus91
Jerseyville IL
Does anyone know what the closet tower to me is I want to hear only district 18 if possible. That's the one that covers where I live.
