W5JCK
I'm going to sell my BCD436HP scanner which has the DMR key installed. Since I paid for that key, I want the key to transfer to the new owner. My question is simply if that is what happens. Is there anything I need to do to ensure the new owner has the DMR key access? I assume there would be no issue unless the new owner did a complete reset in which case that would likely delete the DMR key. At any rate, I want to transfer the DMR key to the new owner so s/he can have it and re-install it if the need arises.
I tried googling this and I tried the search function in this forum, but was unable to find an answer.
Thank you.
Thank you.
