Gahanna PD talkgroups
ducky78
Gahanna OH
Need help with programming Uniden BCD996T
I am trying to just get gahanna PD and MCEE on my scanner and I am getting everything but gahanna.I am new to the digital stuff so this is all new to me.
ducky78
Gahanna OH
I have freescan and the Uniden software on my computer. I removed everything but gahanna in the (GRP) section of freescan and uploaded and I still get everyone else. I manualy put in the freq 857.6125c and talkgroup (17515) for gahanna disp. I get nothing.
pinballwiz86
Missouri
Trunking scanners don't work that way. You have to put it in ALL the frequencies listed. The radio computer selects one for Gahanna PD to talk on at random. If you only have one, you will not hear most of the traffic.
ducky78
Gahanna OH
This is what I have in it now
Name Freq/ID Lockout Tone/NAC Modulation Comment Group
Quick Key: .
Latitude: 039581200N
Longtitude: 083003600W
Range (Miles): 17
859.2625 1 NONE
858.2625 2 NONE
857.6125 3 NONE
857.2625 4 NONE
856.8625 5 NONE
856.2625 6 NONE
772.35625 7 NONE
772.60625 8 NONE
772.85625 9 NONE
773.13125 10 NONE
773.38125 11 NONE
773.68125 12 NONE
Quick Key: .
Range (Miles): 17
GAH EVT 17523 OffNONEOFF0 0 Gahanna Police - Events FranklinCnty25La
MIFF OPS 61067 OffNONEOFF0 0 Mifflin Twp PD local FranklinCnty25La
GAH DISP 17515 OffNONEOFF0 0 Gahanna Police Dispatch FranklinCnty25La
GAH PTL 17535 OffNONEOFF0 0 Gahanna Police - Car-to-car FranklinCnty25La
SO25SIU1 61043 OffNONEOFF0 0 Sheriff Special Investigations Unit 1 FranklinCnty25La
GAH TAC 17544 OffNONEOFF0 0 Gahanna Police - Tac FranklinCnty25La
GHP-TAC2 17584 OffNONEOFF0 0 Grandview Heights Police Tac 2 FranklinCnty25La
Quick Key: .
Latitude: 39581200N
Range (Miles): 20
859.2625 0 NONE
858.2625 0 NONE
857.6125 0 NONE
857.2625 0 NONE
856.8625 0 NONE
856.2625 0 NONE
772.3562 0 NONE
772.6062 0 NONE
772.8562 0 NONE
773.1312 0 NONE
773.3812 0 NONE
773.6812 0 NONE
Quick Key: .
Latitude:
Longtitude:
Range (Miles): 1
GAH EVT 17523 OffNONEOFF0 0 FranklinCnty25La
MIFF OPS 61067 OffNONEOFF0 0 FranklinCnty25La
GAH DISP 17515 OffNONEOFF0 0 FranklinCnty25La
GAH PTL 17535 OffNONEOFF0 0 FranklinCnty25La
SO25SIU1 61043 OffNONEOFF0 0 FranklinCnty25La
GAH TAC 17544 OffNONEOFF0 0 FranklinCnty25La
GHP-TAC2 17584 OffNONEOFF0 0 FranklinCnty25La
  • currentsetup.txt
pinballwiz86
Missouri
Make sure you have to system set to ID SEARCH just in case you programmed the TGID wrong.
ducky78
Gahanna OH
I have an error in freescan no APCO band plan available for franklin county. Is that a problem?
phask
KZZV - SE Ohio
No idea which sites, but around Columbus MARCS and Columbus are on selected towers. Ask or look at some of the posts in the Ohio forum. Looks like you have the same site twice, but your cut and paste is useless to me.
That's where you should have asked anyway.
Disregard that error - means nothing.
J
jlmaddencc
Guest
You don't want ID Search on, you also DO NOT need all Frequencies in Just Control Channels.
40°1′36″N 82°52′9″W (40.026713, -82.869131) Gahanna's Lat and Long not Waynet Twp like your coordinates 39.581200 -83.003600
Current Towers you are trying to USE
859.2625a 858.2625a 857.6125c 857.2625a 856.8625 856.2625 772.35625
772.60625 772.85625 773.13125 773.38125 773.68125
These Closer to you but may not carry Gahanna PD
Bixby (Groveport)Franklin 851.2125 851.4625 852.6875a 853.675c 853.150 853.5125
Discovery (Grove City) Franklin 853.8125c 856.2375 857.1875 858.2375 859.2375 860.2375a
Have you tried Columbus City Site TOWERS since Gahanna seems to be in it's radius
Columbus City Site TOWERS 851.1625 851.4125a 851.6625a 853.0375a 853.450 853.775 856.4375 856.4875 856.9375 856.9875 857.4375 857.4875 857.9375 857.9875 858.0125 858.4375 858.4875 858.9375 858.9875 859.2125c 859.4375 859.4875 859.9375 859.9875 860.2125 860.4875 860.9375 860.9875
ducky78
Gahanna OH
I just got my scanner and put in the talkgroups that are listed and not getting anything on them. Does anyone else listen to gahanna? If so what talkgroups? I also want MECC. Thanks in advance.
radioscan
Radio Sensei
Southern Ohio
The talkgroups are correct as listed, there must be some other programming issue you are having.
Sent from my SAMSUNG-SM-T807A using Tapatalk
ducky78
Gahanna OH
I have the scanner set to ID search and its picking up talkgroups in the 61xxx and 62xxx. BTW its a BCD996T. If i put it in ID scan I dont get anything.
Frequencies i have programmed
Frequency LCN L/O Vol Adj Num Tag
859.26250 1 False 0 NONE
858.26250 2 False 0 NONE
857.61250 3 False 0 NONE
857.26250 4 False 0 NONE
856.86250 5 False 0 NONE
856.26250 6 False 0 NONE
772.35625 7 False 0 NONE
772.60625 8 False 0 NONE
772.85625 9 False 0 NONE
773.13125 10 False 0 NONE
773.38125 11 False 0 NONE
773.68125 12 False 0 NONE
Talkgroups
Display TGID L/O
GAH EVT 17523 FALSE
MIFF OPS 61067 FALSE
GAH DISP 17515 FALSE
GAH PTL 17535 FALSE
GAH TAC 17544 FALSE
GHP-TAC2 17584 FALSE
Gahanna 24736 FALSE
radioscan
Radio Sensei
Southern Ohio
If you want to listen to Gahanna you need to program in the control channel for the Columbus MARCS site, 774.28125.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Is that the only one I need or do I need all the others too?
For GPD you need the Columbus MARCS tower (site 16); for MEC Center you need the Columbus City tower (site 10). Franklin County Sheriff would be either Franklin County (site 61) or Columbus City (they operate on both).
ducky78
Gahanna OH
Thanks for all your help I am now getting Gahanna. What talkgroup would I put in for MEC? Once I get this going I would like to broadcast on here.
Colin9690
Delaware County, OH
Lewis Center, OH
Put in their dispatch, fireground, EMS, and OPS talkgroups as they use them all. Also, put in the appropriate CFD talkgroups such as 9EMS 1, and the fireground talkgroups since these are used for mutual aid runs.
As mentioned, it's all there under the MARCS-IP system.
AK9R
Super Moderator
Central Indiana
FYI, asking essentially the same question in two different threads is known as cross-posting. Cross-posting is generally not permitted in the RadioReference forums. The two threads you started have been merged.
