Token
For the last couple of days I have been looking at a signal that has some of the earmarks of HAARP.
Starting about 2130 UTC on May 21 and 22, 2017, what appeared to be a dead carrier came up on 5125 kHz. The carrier transmitted on a 3 minute cycle every 10 minutes.
On May 21 it came up at XXX7:00z and off at XXX0:00z. I mean for example, the carrier started at 2337:00z and stayed on the air until 2340:00z. Then it was off air until 2347:00z, and transmitted until 2350:00z. Then on at 2357:00 and off 2400:00. Etc, etc, 3 minutes every 10 minutes, starting on the XXX7:00 mark. It did this from about 2130 UTC on May 21 until about 0750 UTC on May 22, or roughly 10 hours of operation.
Further, there occasionally appeared to be some very low frequency modulation on the carrier, for example at 0400:00z - 0403:00z tonight it had swept modulation on it, starting at about 15 Hz and going to about 23 Hz, although most of the time all I could detect was a little 120 Hz hum (which I have seen on HAARP before.
And then on May 22 at about 2130 it started up again. Still on a 3 minute on per 10 minute cycle, but tonight it starts at XXX0:00z and ends at XXX3:00z. I mean it starts on air at 0020:00z and goes of air at 0023:00z, then back on the air at 0030:00z and off at 0033:00z, etc, etc.
Right now (0400 UTC, May 23) the signal is still cycling.
I have seen these kinds of signals for the last few months, off and on, but never really looked at them closely until yesterday. By the way, these signals are heard on remotes across the US and in Europe.
Why do I say this might be, maybe, to be considered, HAARP? The signal strength and characteristics are consistent with past HAARP observations. The bearing of arrival is consistent with past HAARP observations. The low frequency modulation is consistent with past HAARP observations. And finally the 120 Hz hum is consistent with past HAARP observations. Not one of these things, by themselves, is a good indicator, but taken together I think it is worth considering HAARP as a possible source.
T!
T!
