XTL5000 radio id question
wb6sub
Antelope Valley, CA
I am trying to program a multi mode ham radio repeater in my radio. The repeater owner said to program my DMR id (3107112) as the radio ID for the system to work. Can anyone help me to tell me where in the software I put that in? I have looked around in the CPS software and still haven't found it once the radio personality was downloaded. Please help
Skypilot007
Medford, NJ
I think the OP is implying that the repeater in question is running mixed mode P25 and analog. When he uses P25 he wants to use his DMR-MARC radio ID. I do the same thing. You can use any ID you want unless the repeater owner want you to use something else.
I can't remember how to set the ID off the top of my head. I believe it's in the Astro25 system tab under conventional. It's pretty straight forward. if you get no assistance I can walk you through it when I get home and have CPS open.
BigLebowski
Piedmont NC
You need to locate the conventional Astro system. The default ID is "1". Enter your ID into that field, and make sure that you select that Astro system for the conventional personality associated with the repeater you are programming in.
MSS-Dave
Generally Central Florida
You needed to add some info here as some are misunderstanding what you are doing. You are wanting to use your 5000 on a P25 amateur repeater hooked into the P25NX network correct? That network DOES encourage use of the DMR-MARC ID scheme as it is an existing, well managed data base.
Your ID goes under Conventional>Astro systems>Astro system 1>General>Individual ID
I see you have responses so this is redundant at this point.
N4KVE
PALM BEACH, FLORIDA
It's in the Astro ID section, & default is 1. We too use our DMR ID # 's on our P25 repeater's. The ID # is already assigned to us , so why not use the same # for P25 repeater's. One less # to remember.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Wow, I think some people need to take a reading comprehension course.
I suspect the OP is using his P25 radio on the p25nx network. It's suggested that the users of this P25 network use a DMR ID as their ID.
Nowhere has the OP said anything about using his radio on DMR.
As suggested above, the radio ID good in the Conventional Astro system.
Now I'll delete all the wrong replies so nobody else is confused and jumps in.
