City of Hartford - Fire
SVFC462
Connecticut
I see the Hartford fire feed has been removed.
I host the police scanner .. should I apply to host the fire feed as well?
Thoughts, comments??
-KB
connscan
HFD Live Scanner Feed
Back on line with a temp setup. HFD personnel are flat out short staffed. Right now the feed is one channel 154.310 only. Scans Incident 1 thru 5 with priority on Dispatch. Will work with HFD to get the two channel feed back up as time permits. Broadcastify lost a server and the streaming audio encoder needs to be reprogrammed with the new server address.
connscan
Will be back on the primary 6/23
Will be at HFD tomorrow 6/23 to reprogram the primary encoder. Streaming will be offline for a brief period between 10:00 and noon.
