Jake68111
So I went out and got new microSD cards for my two microSD based scanners (PSR-800 & BCD536HP) on the advice of some RR folks.
Picked up the Transcend Information 16GB High Endurance microSD Card with Adapter (TS16GUSDHC10V) off Amazon. Programmed them both/each with the adapter. The 536 took it flawlessly, however, the 800?!?!? Not so much. Have yet to get the scanner to accept it. I get the dreaded Error 03-01 "General error initializing file system". It simply will NOT take. I've formatted this card and an older one the same exact way and the older one works. I thought maybe the card itself was bad so I set it up for the 536 and no issues whatsoever.
Has anyone else had this issue with this card? Can the scanner even accept this card? Should I just stick with the older brand/type that works with the scanner and just buy a new one of "it"?
