XTS2500 Possible Flashcode?
sam55671
NJ
Can a Flashcode of 52001990179B7 be put into a XTS2500 700/800MHZ?
KE4ZNR
Radio Geek
That flashcode decodes to the following:
Flashcode 1 Flashcode 2 Flashcode 3 Flashcode 4
520019-90179B-7
XTS2500
D12 B1 Q806: ASTRO IMBE Digital Operation
D12 B3 H14: Enhanced Digital ID Display
D11 B2 Q52: Federal Government FPP
D8 B1 Q883: 3600/9600 Interoperability/Mixed Mode Signalling
D7 B1 H35: Conventional Systems Operation
D7 B4 H38: SmartZone Systems Operation
D6 B1 G857: FDNY Emergency Rx/Tx Tone Set
D6 B4 H345: ASTRO 25 Trunking Radio Authentication
D4 B1 Q947: APCO Packet Data Interface
D3 B1 Q53: FCC FPP And Radio Cloning
D3 B2 Q387: Conventional Voting Scan
D3 B3 Q173: SmartZone Omnilink MultiZone Operation
D2 B1 Q575: 3600 Baud Trunking (Analog/Digital Voice)
D2 B4 Q361: ASTRO 25 9600 Baud Trunking
D1 B1 Q445: Fireground Accountability Software
D1 B2 Q446: Fireground Voice/Channel Announcement
D1 B4 Q574: 9600 Baud Trunking
You possibly could force that Flashcode into a radio by why would you?
So much redundancy and a few of those feature codes conflict with each other.
Keep the flashcode simple.
Marshall KE4ZNR
sam55671
NJ
You'd likely want the reband option as well.
Doesnt rebanding only have to do with the host version? I did not see a Flashcode option for rebanding.
N4KVE
PALM BEACH, FLORIDA
I try to keep my flash codes as simple as possible. In my case, why have all those trunking features on a radio that will never be on a trunking system. The above code is not legit, & loaded with features that will not work with each other.
sam55671
NJ
I plan to use the radio for non affiliated scan on the New Jersey State Police System and The Connecticut State Police System which are both SmartZone Omnilink, but I believe NJ is 3600 and CT Is 9600. I need a Flashcode that will do 3600/9600. Will this option be enough?
com501
If you can't determine the correct flash, then no-affiliate scan is going to be even harder to get right. You need an Elmer before you brick your radio.
Find someone with a WORKING radio and look at that flash before you eff things up to badly.
sam55671
NJ
This is the current flash 5000080004105. It should work for NJ but I do not think it will work for CT.
clbsquared
Isle of Wight County
Just add Q574 to that flashcode and you should be good. Having all those additional features is not necessary. Whoreing out a flashcode is never a good idea. Why would you need all of those Fireground features? Or the cloning feature. Keep it simple.
Sent from my HTC One A9 using Tapatalk
N4KVE
PALM BEACH, FLORIDA
I just don't know how people get these flash codes with features that do not work together. My go to guy who upgrades my radios can only use real legit flash codes. When he tries to install bogus ones like in the OP, the program will not allow it. The program will then provide a genuine flash code that's closest to the bogus one.
CanesFan95
FL
What program is that?
CanesFan95
FL
I've been trying very hard to get my foot in the door with Motorola and nobody will help. Like how to get around the system key problem and do non-affiliate scanning for P25 simulcast. How come everyone else knows but won't tell me?
clbsquared
Getting your foot in the door with Motorola is an easy task. Just set up an MOL account and they'll gladly take your money for just about anything you want. Aside from a system key and certain CPS, the sky is the limit. No one on this site will discuss the particular software used for creating system keys, because it's illegal.
There's a metric ton of information on the web regarding NAF scan. Most of us took the time to research it on our own by reading thread after thread in multiple other sites. No one is going to spoon feed you information on this subject because of the serious consequences involved if you get caught.
GTR8000
NY/NJ Database Guy
BEE00
Because we don't discuss that crap around here openly...period, end of story. You've been around long enough to know that by now, so instead of whining about it, learn how to use Google to find other resources that permit that type of discussion. :roll:
And to answer the other person's on-topic question: yes, Motorola still provides Flashport upgrades for the XTS 2500, for the time being at least (but not for the XTS 5000).
sam55671
NJ
Why Not The XTS5000?
