MDC-1200 in Kenwood 5000 series
Cave City, AR
Having problems getting MDC-1200 signaling to work in analog channels in the 5000 series radios. Have tried numerous combinations of settings. I want to display the unit ID of the radio on all other radios. Can anyone give me some settings.. hints etc.
THanks
kd4efm
Florida
Channel edit the channel, at the bottom, analog MDC section, began of transmission, end of transmission, or both, then the PTT ID will transmit from the 5000, after you program the radio.
Sent from my SM-G935P using Tapatalk
AJ1L
Rockland, MA
I'm having an issue where the radio is displaying the MDC IDs fine, but that it stays on the display until another ID is received, or scans to a channel that it doesn't hear an ID on. I expected it to be the auto reset timer, but it doesn't seem to be. Is there a way to have the MDC show smaller under the channel name? My DMR IDs show that way, but can't figure out where the settings are to change the way it's displayed.
kd4efm
Florida
Size is hard set. MDC is a reset, for got where, busy doing installs, can help later.
AJ1L
Rockland, MA
I think the issue may have been that I didn't have the LCD box checked under auto reset. I'll find out later when I write the codeplug to my radio.
ndejohn
Middletown, Connecticut
Kenwood needs to do another firmware update and add some more DOS hold off features on MDC like Motorola has. I use MDC all the time and some of the agencies that use MDC have it on post, and I hear the entire data squak come through. It's rather annoying.
