Using radios in cat rescue
N2UJZ
Sarasota, FL
I really didn't know where to ask but I do volunteer work with a local cat rescue program. Part of it is trapping feral cats to be vaccinated, fixed & released.
Anyway since I often have to monitor several traps from a distance I have been putting my UV5Rs on a MURS channel low power with VOX at lowest (1) and roger beep (or PTT-ID) near trap so when a cat sets it I get tones. I know I'm not supposed to use my UV5Rs on FRS/GMRS but am I OK on MURS? Sam's Club uses Ch 1 so I avoid that.
I'm also a ham so not sure if it could be used in that way on 2m or 70cm. Just want to make sure I'm not doing anything I'm not supposed to though.-justin
toastycookies
the far east
You'd prolly do better just using a ham frequency on 2m or 70cm.
Check Part 95J.
Unless the radio has Part 95J, as Toasty said, it's not legal for use on MURS.
-Yes, we know that most people just ignore that fact and do it anyway, but you are asking if you are "supposed to".
I agree, if you have an amateur license, pick an appropriate 70cm frequency and use that. You'll still need to figure out a way to ID, but that's not impossible.
RFI-EMI-GUY
The ISM band 433 MHz is shared with 70CM ham band and you can buy some cheap part15 transmitters for remote control and give them a boost with an amplifier. Limit the transmit time so you dont screw up car key fobs all over town. Program a tone sequence and CW ID using a PIC chip.
N2UJZ
Sarasota, FL
I knew there are some (mostly unused) parts of 2m and 70cm for experimental, beacons etc, so I'll check into what freqs. I've done range tests because I was trying to trap one a bit over a mile away from home and even with a Nagoya 771 on both it was not strong here.
But just wanted to check though. I seriously doubt a few seconds of tones at low power late at night is bothering anyone (except the time I forgot to turn vox off- oops!). I'll check into ham bands though.
I can ID using my receiving radio I always of course turn volume down on the others. So far this weekend caught 4 kittens for rescue & adoption.... Bravo, Charlie, Delta, and Echo! Thanks everyone for ideas.
Rred
On the one hand, "no harm no foul" often works.
On the other...I can't think of any radio service where it is legal or proper to let animals control the transmissions. Which is what those cats are doing.
Convert a driveway monitor or other "device" that uses an ISM frequency or similar, instead of hijacking voice services, and you'd be totally in the "no harm no foul" territory.
Or, just forget the rest of the details and roll your dice on flying below the radar. Which is what it is, MURS or Ham or whatever.
N2UJZ
Sarasota, FL
"Hijacking voice services" :p
Yes hanging around parking lots late at night shining flashlights under cars and generally looking suspicious is part of the work but I'm no hijacker lol.
jwt873
Woodlands, Manitoba
Good to hear you volunteer. I'm a cat owner.. (Sitting at my feet as I type this). Do you also rescue giant cats :) :)
