Trump visiting NJ for 18 days
RadioDitch
Signals Identification Member
All over the map.
spongella
W. NJ
Thanks for the tip. Also means drone ops are grounded those days if you're in the TFR ring. Better get in some flying while you can hi hi.
RadioDitch
All over the map.
I work about 2 miles from the golf course, so I may be able to try and decode that 380 system.
If you can find it and work on it, it would be great. It appears about 30mins prior to AF-1 landing, and then seems to follow the motorcade. If it is indeed mobile, it's likely on-board the IDC, HTUV, or Roadrunner. It's generally in the clear and appears to be back and forth between aircraft and the USSS.
There also seems to be a few DMR frequencies in the 400-415MHz range, but they may just be images of local 900MHz signals around EWR..
KK4JUG
GA
I'm nowhere near NJ so I won't be able to monitor anything. It'll certainly be more fun than working the detail. Over the years, I worked several presidential and presidential election visits. They can be a pain in the keister. Plains, GA, is only about 50 miles away and Jimmy Carter was (and still is) a frequent visitor here in Columbus. Fortunately, his visits now are more discrete personal protection and low-key escorts (if there's even an escort) rather than full-scale motorcades and all the accoutrements that go with them.
rwier
Phoenix, AZ
18 Days in NJ? Talk about self-flagellation, lol. No offence to NJ aficionados, but the closest I would get to NJ is Scottsdale, Arizona!
RadioDitch
All over the map.
Every time I come home to New Jersey from the road, my hand is on the directional signal stalk to make a u-turn. So I hear ya. :D
crazyboy
NJ
Your first mistake, using a directional. They take them out of cars sold in Joisey!
ecfc127
Trump will leave the White House at 3:45 today for Joint Base Andrews, where he will depart at 4:05pm for Morristown, New Jersey; he's expected to land at 4:55pm.
Trump is expected to arrive at Trump National Golf Club in Bedminster, New Jersey, at 5:20pm.
ion_op
Chemtrails
Just saw a F-15 do a barrel roll over Green Brook//Bridgewater. What Mil freqs should I be monitoring?
Tnx,
Mike
