set-up ProScan on PC to work with BCD536HP scanner
dpw5rp
MA
I have already downloaded ProScan to my PC and purchased a license,I just can't get it to work.I get a message UDP not connected.Im not even sure Im setting it up correctly. If anyone could help that would be great.
eaf1956
Evansville, IN
Make sure the scanner is connected to the local wifi. Also, be sure you use the correct IP address. If you use the scanner in AP mode your computer has to be connected to that Access Point and if you don't have any other connections you will not have internet.
dpw5rp
MA
Set-up Proscan on PC,BCD536HP, Results
I changed from Access point mode to Infrastructure mode and made a changed 1 digit in the URL, the BCD536HP and the ProScan now work great together including audio. ( Thankyou. eaf1956 ) for your post. dpw5rp
