Motorola Radios Missing Pixels Question...
N1SQB
Somewhere On Earth
I have never had to deal with this issue personally but I'm curious about something. Are missing pixels on a radio display a sign of a bad LCD or is it something else? I mean will simply replacing the display solve the issue?
Manny
Project25_MASTR
Millennial Graying OBT Guy
Texas
Generally yes. On radios like the Astro 25 line, I've yet to see just a few pixels go out (usually the entire display does something funky). Now I did have an XTS3000 that had a pixel or two drop out.
gatekeep
FAIL 01/93
New York, NY
Depends. Usually with a lot of MTS2000 and XTS3000 radios, due to a bad bonding agent the displays lose pixels because the flex on the parallel connector between the display interface and the literal LCD module fails causing loss of rows and/or pixels. IIRC this was covered in an SRN by Motorola, in this instance replacing the display fixes the issue.
rescue161
KE4FHH
Hubert, NC
On the Astro25 (XTS2500/XTS5000) the display can go completely out or sometimes it can be missing a whole row or more. It is usually a torn flex if a row or two is missing. In either case, the display has to be replaced.
N1SQB
Somewhere On Earth
Thanks guys! I have 3- XTS3000s. VHF/UHF/800. All are in excellent working order with no display issues.
I know it can happen at anytime so if it's as simple as replacing an LCD screen, I want to be ready with a replacement or two just in case.
Manny
com501
The XTS3000 display is no longer available from Motorola. I have not seen a Chinese vendor make a replacement yet. Your best bet may be to purchase some more XTS3k's in any band, the display is the same for every band.
com501
I doubt that it is new, the film over the display is missing. Chances are these are pulls from surplus. Still a good deal, that is below dealer cost.
