G4 - Battery charging light and rebooting
troymail
Silent Key
Noticed recently that the normally red/green battery status LED on my G4 - which has been on my desk charging with a USB cable for the past few days - went dark several times. When I pull the cable and reinsert it, the LED lights back up but RED vs. GREEN.
A few moments ago - again, with the LED dark - I witnessed the radio reboot itself....
Anyone else seen this?
ecarvalho
Well
I don't know if this is related or relevant to this thread but yesterday I found my G4 dead with no battery juice sitting on the base charger.
I had to recharge it with the USB cable. It's almost as if the change stopped at some point and gave up recharging.
rogress
Chesapeake, VA
Same thing just happened to me this week. I was able to "kick start" it with the USB charger, then put it back in the base and it charged back up. I'm suspecting that it isn't seating properly, but I'm not sure.
Note that the base charger worked on the G5 immediately after I swapped radios.
IAmSixNine
Dallas, TX
Battery related - ON my G4 using the drop in charger, i was getting that error 7 issue a lot. I re-programmed my pager with a couple channel mods and later did a battery pull. 2 weeks now and not one single error 7 issue.
probably not related to what you guys are experiencing but a battery pull helped me.
