1) When you post in all capitals, it conveys the impression that you are screaming. If that is your intent, same can be expressed without using all caps.
2) This post would be best re-located to the New York forum.
3) Private Line is Motorola's term for what has commonly become known as a "PL tone". Which is truly a misnomer, but that's beside the point. Look up and research CTCSS tones. You might have the correct frequency programmed, but the wrong tone.
For a hypothetical example (and agencies here in Vermont absolutely love to do this more than anywhere else I have lived), your local police primary repeater output may be 460.100MHz with a CTCSS tone of 100.0.
If you program that into your scanner, you will not hear, for instance, the car-to-car chat that takes place on 460.100 simplex with a tone of 71.9, or the city park bicycle patrol's low-power repeater on 460.100 with a tone of 203.5.
