Motorola CDMA 1550 LS remote mount.
N6RDT
USA
I have a CDM1550 LS +. When I separate to radio and control head I can't program through the the RG45 mic connector. I can when it's together. Anyone have an idea why?
I've heard of this happening before, but it's never happened with any of mine (1550, 1250, 750).
One option is to program through the rear 20 pin connector. You can buy the 16 pin connectors off e-Bay and build your own cable. You don't need the outside 4 pins for programming.
firefive76
Kansas
I've had the same issue when using an aftermarket ribless cable. If you use a RIB & cable, it will program remotely.
Skypilot007
Medford, NJ
I use a ribless cable from kawa mall and mine will program through the remote head. Two 1550's and 1 1250, no problems. They are not LS+ models however.
com501
Remote cable must be 10-pin, not 8pin RJ45. Firmware version has to be newer, I don't remember the exact version.
motomeso
Ontario
Back in the prime days of the Waris radios it was considered taboo to program a trunk mount CDM radio and recommended to put the head back on the radio or program through the rear accessory. YMMV
I've never had an issue using an 8 conductor RJ-45 cable. I've done this several times in the shop and on a vehicle. Never any issues programming from the control head.
My understanding as the outboard pins are used for the handset audio. If you are not using the handset, you can use the 8 conductor cable between the RF deck and the control head.
N6RDT
USA
Thank you all for your suggestions. I was using an after market ribless cable. I have the after market kawa rib box that I use to program my astro sabers and it does just fine.
