I have been struggling with this for a few days and can't seem to figure it out.
I am looking at a broadband rf amp (20mhz wide). With no signal fed into the system, I get a nice fat hump tucked nicely inside the filters:
l l
........l l.............
I believe that his hump consists of 3 things:
the amplifier gain (which is 80dBm)
the noise figure of the amp (which is speced at 4 by the manufacturer)
the noise figure of the spec a (which I calculate to be 28 without the internal pre-amp, 16 with the pre-amp)
No matter how I do the math, my measurements never add up.
I am starting to think some of my basic assumptions are incorrect.
What is the math that drives the size / power of this hump????
Using the marker to noise floor option I get:
Peak to peak measurements: noise floor -135, amplifier -90
Channel power measurements: noise floor -61, amplifer -16
I believe the difference of 45dB is the same because the hump is very uniform.
How does 80dBm gain + any noise figure = 45dB???
NOTE: I used the external attenuation option on the Spec A to factor all cables /adapters out of the equation.
l l
