I've been through the manual, and the easier to read manual available online, and I can't get some features of the scanner to work. Specifically, adjusting the decode level down to a manual 8, or enabling attenuation on the scanner.
You can adjust the Digital Threshold or set Attenuation on either the scanner, or in Sentinel.
For the Digital Threshold settings, such as "manual" and "8", press Menu
Then scroll to and press "
E" (Yes) to select
Manage Favorites.
that gives you the Favorites lists loaded on your scanners memory card.
Scroll to the list you want to tweak & select it (pressing
E)
Next, Select
Review/Edit system
For a
Trunked system, scroll to the system you need and press
E to select it.
From the list of options once you select the system, scroll to and select
Edit Site
Scroll to the site you need to change (if there is more than one), then press
E to select it
In the list of options on the Edit Site screen, you'll see
Set Attenuator,
Digital Threshold Mode, and
Digital Threshold Level. Select any of these you wish to change, and press
E to select that option.
Make your changes, then either press System (or <FUNC>+<SYSTEM> to resume scanning, or press
Menu to to back up one screen (to tweak another Site on the same system), or continue to press Menu until you get back to the point where you can either select a different System to modify, or back up further to get to the screen to select a different Favorites List.
For a Conventional system, select the Favorites list that contains the system of interest.
Next, scroll to the system, pressing
E to select it.
To change the digital threshold settings, scroll to and select
System Options
The
Digital Threshold Mode and
Level settings are on the
System Options screen.
To change
Attenuation settings on a
Conventional frequency, that setting is made on the
Channel itself.
Select the
System that needs to be changed.
Once you've selected the System, next select
Edit Department
Scroll to and select the
Department which contains the specific frequency (channel) that you want to change
Attenuation.
Once you've selected the Department, select
Edit Channel
Scroll to and select the specific
channel and then change by selecting
Set Attenuation from the menu.
Once you're done with that frequency, back up as much as necessary to get to the next Channel or Department that you want to tweak. If done, just resume scanning.
Be sure that you either use Sentinel to "read" from the scanner so that the lists on the scanner match the lists in Sentinel, or make the same changes in Sentinel.
Of course, you could always make all your changes in Sentinel then write the updated list(s) to the scanner. In Sentinel, access the Favorites List editor, and select the list you wish to change. On the edit screen, for
Trunked systems select the site(s) you want to modify, then click on the
Options tab for the site to change
Attenuation or
Digital Threshold settings.
For Conventional systems, the Digital Threshold settings are accessed via the System's
Option tab.
I pressed CHAN to hold on to a Talkgroup on the Cabarrus NC Simulcast from the Charlotte UASI system, and hit function, then pressed 4 and it gives me an error beep.. What am I doing wrong exactly..? I need to enable the attenuation on this due to the issues of Simulcast Distortion, but it seems I can't adjust ANY parameters via the scanner, or the software.
You cannot set Attenuation on a specific
Talkgroup. Which is why the <
FUNC>+<
4> did not work. It does work when holding on a specific Conventional channel.
