G1 Won’t Charge
apx7000xe
GA/SC State Line and South GA
I have a G1 and it will not charge. I can take the batteries out and they charge just fine but they won’t charge in the pager. I keep getting a red blinking light and the manual says “abnormal condition” Please help. It’s my only way of knowing if we have a call.
hiddenrun
Commonwealth of Pa
1- Make sure the contacts on the bottom of your G1 are clean.
2- Also check the contact pins in the charger and make sure each of those still spring up and down.
3- Make sure you are using the original charging cord for the charger.
4- Lastly, if you can get the G1 to charge by holding it upright and tight in the charger, it may be an issue of worn case rubber.
David_Oney
Former Unication Tech Support
Raceland, KY
There was a design change in the G1 Charger to combat worn rubber on the unit causing it to not charge efficiently. If you have an old unit/charger please contact your dealer and you can send the charger in to be refitted.
