Howdy All,
So I was trying to set a PTT ID for my radio. I programmed it in same place where I set it to read the ID's which works.
While the radio puts out an ID with squalk after my transmissions it is not putting out what I put in the radio. Does this have to be done in some sort of Hexadecimal code? I figured what I put it the radio would see, though I did realize some letters did not work when messing around.
I tried searching the forums but did not see anything.
For instance, was aiming for 214B but got 7155 on the output when other radios check my ID.
Thanks in advance for any advice
