firemedic78
Hello, I can use some help real quick, does anybody out there with Kenwood experience and knowledge, know what software is needed to program any of the NX 3000 series radios? I'm looking to purchase NX 3200 VHF, and I'm trying to find software for it, I have the programming cable, because I'm selecting the 2 pin accessory Port model. In fact, I've even got the 14 pin accessory for programming cable as well for other Kenwood radios that I had, but none the less, I would much rather stick with the 2 pin accessory port model because of how easy it is, you don't have to try and line up the notches and then screw it in with the 14 pin accessory version, plus, I already have extra lapel mics from my Kenwood TK 2312 that has the same 2 pin accessory for, so therefore I don't need to spend extra money on lapel mic's because the 2312 and the 3200 2 pin accessory port is compatible with each other. All you need to do, it's just push in each little pin into the accessory Port Jack. Anyway, back to my original question, does anybody know what software the NX 3200 requires(KPG???), and how I may go by getting or purchasing it? Also, is it the same software that programs other NX series radios, like the NX 320, 220, ect...Or is there only one compatible software specifically for the NX 3000 Series alone. Thank you for your help in advance.
Chris
Chris
