Yaesu: Tuning with an FT-757 GX II
WB4UR_Sean
Amelia, VA
Name here is Sean, WB4UR
Rig is a Yaesu FT-757 GX II and using an MFJ 245-E Tuner.
Antenna is an HF5B / Butternut on a mast 30 Ft up on Rohn Tower.
Having a time tuning to get a low SWR when using SSB - mainly Upper Sideband.
What Frequency and Mode is recommended to tune up on. (I hear CW or AM)
The Inductor is labeled A - L.
I have had the HF5B since 2005.
Whenever I tune for the lowest SWR and think that the SWR is low, I key up on a vacant frequency and the SWR needle goes up at the same time. I have the tune button in the out position when I do this.
I would like a refresher instruction on tuning up on the bands, especially on 20m if I want to check into the net on 14.300 USB. Is there a video on YouTube that would steer me in the right direction?
Thank you :)
73s
de
WB4UR
ko6jw_2
Santa Ynez, CA
The Butternut should have a 200Khz bandwidth on 20M. Tuner should not be necessary. What is the SWR without the tuner?
You should tune/measure using AM or CW (key down) at low power. You cannot measure/tune on SSB - no carrier to measure.
Do you have a separate SWR meter or are you using the tuner?
I cannot find info on the tuner.
Checking that the antenna is working would be the first step.
wb6uqa
Santa Monica, Ca.
757
You must tune with a carrier, cw or rtty mode. When you take off the top cover there is a switch to transmit on all received frequencies. On the back are switches that must be out or it will not transmit
