This is what I was looking for and could not find, thank you for the help and sorry if I stirred up some feathers NO WORRIES.
Can you restore RF by pulling the batteries and wall wart and holding the power button for 30 seconds or so to drain the caps?
Try that and see if RF does not come back after you plug the wall wart back in. It may need the reset button to be held in the battery compartment but mine has always restored the front end by holding the power button with no batteries and no wall wart. Sometimes I can restore it by simply power cycling the radio via the normal power button but not always.
Back in 2014, Uniden released some Beta firmwares in the 2.06.xx range.
When they did this, it enabled a Manual P25 decode value to be selected from a hidden menu under the Audio Settings menu.
After several months, the beta thread grew silent but others did report that the front end was shutting down at random. You did not know until you realized you had not heard anything for a while or you happened to notice the RF bar graph signal meter was no longer showing anything but grayed out bars.
The last known Beta was version 2.06.08.
You can only see the full beta version by looking at the file on the SD card named HomePatrol.info. It is just a text file and contains the full running version of the current firmware loaded in the radio.
The radios Version menu only shows the 2.06 but does not show the least significant version info to the right of the 2nd decimal point.
About a year or two later, Uniden took the 2.06.06 Beta version and made it an official release version so those that checked for firmware with Sentinel would be given this version as the latest version. The official version is bit for bit the same as the 2.06.06 beta.
The now latest version still has the RF front end shutdown bug that the beta versions had. Many did not report the front end shutting down so maybe there was a hardware difference in the HP1s that we never knew existed like a logic board revision or something.
The only good thing about the released version of the beta is it still has the hidden option to select Manual P25 decode setting for those that need that. That one is kind of stupid though as the setting does not stick through a power cycle, in the beta or release version.
That option does allow for reception of many simulcast P25 sites that are normally so choppy that you cannot monitor them. The drawback is the front end shutting down at random.
Nobody ever figured out what causes the front end to shutdown after installing any of the 2.06.xx beta versions but they all did it.
Mine will run from 5 minutes to several days or more before the front end turns off. I find the beta version 2.06.04 was the most reliable and not the 2.06.06 version Uniden later made the official release version.
Anyway, if you find you can restore RF by removing all power and draining the caps, you may benefit from an older pre beta firmware such as 2.05.03 which I think was the last official release before the beta's came out for testing. If that works, just remember to keep a copy and not use Sentinel to check for firmware unless Uniden comes back later with a fix for this but I think that may be unlikely.
You will no longer have the hidden option to select a manual P25 decode threshold setting if you go back to 2.05.03. Switching versions will not affect the Extreme upgrade if you have that.
My HP-1 has been working fine with no front end shutdowns occurring since I went back to FW 2.05.03.
I cannot monitor a favorite simulcast P25 site worth a darn but that is no longer much of a problem as the entire system went nearly 100% encrypted. Non-simulcast P25 sites work very well and do not seem to be bothered by the P25 decode running in Auto mode which is how the HP-1 works without any of the 2.06.xx FW versions.
If you use Sentinel and did a firmware update in the last year or less, you were given version 2.06.06 which is the same, bit for bit, as the Beta version 2.06.06 was.
There was also a beta version 2.06.08 as well but they released 2.06.06 instead. I don't recall what 2.06.08 may have corrected or broken.
The thread discussing this is at:
https://forums.radioreference.com/uniden-tech-support/294284-homepatrol-1-2-06-xx-open-beta.html
You should see mention of the front end shutting down in that thread but it is a big thread so it may take some time to search through it all.
